Briggs & Stratton model 23 spark advance
this thread has 2 replies and has been viewed 1715 times
Old 12-31-2014, 11:48:38 PM
54hawken 54hawken is offline
Smile Briggs & Stratton model 23 spark advance
Concerning cam gear, spring and weight. need someone to explain in detail how it works. What the weight activates etc.
Old 01-02-2015, 03:46:49 PM
Default Re: Briggs & Stratton model 23 spark advance
There is no spark advance on the 23. The weight works to slightly open the exhaust valve on the compression stroke, making it easier to start the engine. As speed increases, the valve de-compression lift decreases, giving full action of the exhaust valve. If the return spring breaks or is missing, valve action will be erratic.
Old 01-11-2015, 11:45:22 PM
I found an old briggs & stratton repairmans manual. It showed, and said:
The shaft that comes through the engine block into the external points/condenser box and hooks to the points, has an integral shoe on the opposite end that is moved by the camgear weight. When the engine is started (low rpms) the weight is held in by a spring. As the rpm are increased the centrifical force overcomes the spring and moves the weight outward, pushing the shoe, which rotates the shaft slightly to advance the timing. when rpms decrease the spring retracts the weight to retard timing. This feature makes for easy starting for a 9hp. No kickbacks & sprained fingers. Also no backfiring thru carb when accelerating.
---------- Post added at 10:39 PM ---------- Previous post was at 10:36 PM ----------
I neglected to say my above 2 posts are for Briggs model 23 with Magnematic ignition system
---------- Post added at 10:45 PM ---------- Previous post was at 10:39 PM ----------
sorry for edit
The Following User Says Thank You to 54hawken For This Post:
Briggs and Stratton odd spark plug bemis368 Small Air Cooled Gasoline Engines 3 12-01-2014 10:35:40 PM
Briggs & Stratton Ignition failure (no spark) jools Garden Tractors and Mowers 3 06-03-2011 07:04:37 AM
Briggs and stratton low spark (HELP) Ricky Harris Garden Tractors and Mowers 5 03-29-2009 10:42:12 AM
Briggs & Stratton 5S Engine No Spark whargrov Small Air Cooled Gasoline Engines 19 01-09-2009 10:47:03 PM
Briggs and Stratton 60102 no spark? buddy m Garden Tractors and Mowers 4 04-19-2008 10:16:27 PM
