Fairbanks Morse exhaust timing..new tool
this thread has 8 replies and has been viewed 1868 times
Old 06-24-2012, 08:49:25 AM
Warren Eastham Warren Eastham is offline
Default Fairbanks Morse exhaust timing..new tool
Gentlemen,
Old Engines........New Tool!
I recently had occasion to adjust exhaust valve timing per "The exhaust valve lever should touch valve stem to open exhaust valve when the crank pin is between 35 and 40 degrees above outboard dead center." I did this by eye and it worked well. Then, later I realized that the digital level app in my smartphone would work well to get this angle easily and accurately.
(This is actually a good use for a smartphone!)
Warren
Old 06-24-2012, 11:23:41 AM
Exclamation Re: Fairbanks Morse exhaust timing..new tool
Good rule of thumb, the exhaust valve must close at or just after TDC exhaust stroke. Too early or too late will greatly affect engine performance!
Old 06-24-2012, 11:51:28 AM
73eldo 73eldo is offline
Default Re: Fairbanks Morse exhaust timing..new tool
Where are you placing the phone to measure the angle?
Old 06-24-2012, 01:52:07 PM
73eldo,
What I call the "throw", the two arms that hold the journal, or pin, that the piston rod connects to.
Good Luck,
Warren
Old 06-24-2012, 05:36:42 PM
Martin Gaudet Martin Gaudet is offline
They should make a "smart-magnet" to stick the smart-phone to the shaft! Maybe put a nice brass tag with the maximum rpm rating on the magnet ...
Old 06-24-2012, 08:53:11 PM
Roger Kirschenman Roger Kirschenman is offline
Originally Posted by Warren Eastham View Post
Gentlemen,
I recently had occasion to adjust exhaust valve timing per "The exhaust valve lever should touch valve stem to open exhaust valve when the crank pin is between 35 and 40 degrees above outboard dead center." I did this by eye and it worked well. Then, later I realized that the digital level app in my smart phone would work well to get this angle easily and accurately.
(This is actually a good use for a smart phone!)
Warren
What is a smart phoneWe old guys don't know all that new stuff or can afford it
Old 06-24-2012, 11:18:35 PM
Walter Neumann jr Walter Neumann jr is offline
should do a youtube video on how you did it
Old 06-26-2012, 06:10:59 AM
You aint missing much. What your momma gave you works better, plus it fits neatly between your ears.
Old 06-26-2012, 09:38:10 PM
Preston Wells's Avatar
Preston Wells Preston Wells is offline
I use a magnetic protractor that I got from Harbor Freight a few years ago to set the pitch on airboat props. Works well on 5hp and larger flywheels if the application allows.
"There is more to life than what we see"
www.youtube.com/user/theoldengine1
Preston
FL
Fairbanks Morse Exhaust Pot Lou Hit & Miss Gas Engine Discussion 0 02-11-2011 04:49:17 PM
Fairbanks Morse Mag timing skypilotf4u Magnetos, Ignition Coils and Spark Plugs 4 10-25-2009 09:42:55 PM
Re-timing a Fairbanks Morse 3hp Z Ray Cardoza Hit & Miss Gas Engine Discussion 2 11-17-2008 03:34:54 AM
Fairbanks-Morse ZC 8-9 H.P. Timing petrol smoker Hit & Miss Gas Engine Discussion 1 06-17-2008 06:45:24 PM
Fairbanks Morse Z D 1 1/2hp timing Roger Antique Engine Archives 1 10-15-1999 05:15:14 PM
