Battery box metal or wood
this thread has 3 replies and has been viewed 1701 times
Old 11-28-2003, 11:21:32 PM
Don Nelson
Default Battery box metal or wood
I have a fuller Johnson farm pump. I have restored completely accept for battery box . The only one I have seen is on Harry"old engines it had a metal one Does it matter If it is metal or wood. your advise welcomed Don
Old 11-29-2003, 06:34:50 AM
Benny Mckheean in NC
Default Re: Battery box metal or wood
I prefer wood because of keeping the coil and battery from shorting out on the inside of the box.
Old 11-29-2003, 07:14:51 AM
Mark Congden
I'm not an "original nut" so I'd go with the wood also... Mark Congden
Old 11-29-2003, 09:28:41 AM
NICK
The F&J pump engine battery box had a wood bottom and a fiberboard liner that went around inside of steel box. A metal L bracket held the buzz coil upright while the 4 dry cells were bunched next to it.
Cheers! NICK
Fuller & Johnson Mfg. Co.
What is it - Small Wood Box of Metal Prongs Rick I Farm Antiques and Collectibles 5 08-14-2018 05:49:37 PM
Wood Patterns for Metal Castings contractor1977 Wood Shop and Projects 41 01-05-2018 12:24:31 AM
Metal Associated battery box Rich Mueller Sr Hit & Miss Gas Engine Discussion 6 01-03-2016 01:16:29 PM
What have I got here, Wood or metal lathe? Randy Hart Machine Shop and Tool Talk 7 09-25-2009 10:37:54 PM
A bit of metal and wood working I've wanted Paul Spence Hit & Miss Gas Engine Discussion 22 06-09-2007 10:41:39 AM
