Paint Shop
Paint Remover/ Degreaser
this thread has 10 replies and has been viewed 999 times
Old 07-30-2018, 10:02:35 PM
Hubbie Hubbie is offline
Default Paint Remover/ Degreaser
I've been working on the front axle and frame of my restoration project. Trying to remove 90 years of grease and old paint has been a real challenge. After a lot of hard work and little progress, I called it a night. I had to stop at the store while at work and on the way to check out I found the answer, easy off oven cleaner. After getting home a giving the frame a quick spray and about 2 hours of waiting, I grabbed a paper rag and wiped and all the paint and greasy mess way gone. Definitely a labor saver. It's been great.
Has anyone else tried this?
Old 07-30-2018, 10:20:39 PM
Steve Kreiner's Avatar
Steve Kreiner Steve Kreiner is offline
Default Re: Paint remover/ degreaser
Been using for a long time. Works great.
Old 07-31-2018, 07:27:56 AM
Chuck Rhoades's Avatar
Chuck Rhoades Chuck Rhoades is offline
Default Re: Paint Remover/ Degreaser
Try the cleaner for grills. Works even better.
I can build that!
Old 07-31-2018, 07:45:07 AM
Big Bird Big Bird is offline
I have used ez-off in the yellow can to remove custom painted lettering from the sides of vans for years while detailing for whole sale car dealer's. The Blue can doesn't work as well...
And Ez-off Will not harm factory paint, make sure to use cemical gloves or it will soften up your fingernails and turn them yellow.. ask me how I Know....
Old 07-31-2018, 08:31:28 AM
Troll's Avatar
Troll Troll is offline
Purchase pounds of Sodium Hydroxite Pellets, (Lye, food grade) and using very hot water mix the pellets into the water until it smells like old Lye soap your grandma used to use. Then add a little more. Use corn starch to thicken the mixure to a slightly runny, (sagging when applied vertical) texture and spray it through a cheap automotive spray gun with a large fluid tip onto the surface needing cleaned. Wear protective clothing for sure. The hotter the temperature, the faster the cleaning. I heat it up with a side burner from a former propane grille.
If you spray on bare aluminum don't let it dwell as the Lye destroys aluminum rapidly.
The cost if mixing yourself is about 10% of what the "Easy-Off" will cost for the same amount of cleaning.
Old 07-31-2018, 10:29:46 AM
Will easy off damage aluminum ?
Old 07-31-2018, 12:29:17 PM
Ken Karrow Ken Karrow is offline
Hubbie, yes.
Old 07-31-2018, 04:58:30 PM
Ken Majeski's Avatar
Ken Majeski Ken Majeski is offline
I find that the New Easy Off is not as good as it was 20 years ago. Hard to buy anything any good any more
Can't get LYE any more as they think your going to make drugs.
Ken Majeski, Ellsworth Wis.
The Following User Says Thank You to Ken Majeski For This Post:
Old 07-31-2018, 07:06:22 PM
Troll's Avatar
I have no problems acquiring sodium hydroxite. Whether it's 10#, or 2500#. It's the main ingredient and referred to as "Caustic Soda". Does a really good job on anything ferrous in nature.
Old 08-02-2018, 07:40:28 PM
So what is the best to use on aluminum to remove grease and paint?
Old 08-02-2018, 08:38:27 PM
fumo fumo is offline
Hubbie, try Kleanstrip aircraft paint remover from eastwood .com. It's made for aluminum.
Degreaser recipe dadam2308 Paint Shop 5 02-18-2013 02:24:13 PM
degreaser what do you use? ronny p 148 Farm Antiques and Collectibles 14 01-01-2013 05:33:14 PM
best degreaser to clean a engine Matt McGivney Hit & Miss Gas Engine Discussion 4 10-22-2009 11:21:37 AM
Great cleaner/degreaser Craig Curtis Paint Shop 2 09-12-2006 08:36:12 PM
Non Petroeum Engine Degreaser Patrick Traubert Antique Engine Archives 1 06-20-2004 10:37:19 AM
