Magneto Charger Switch
this thread has 9 replies and has been viewed 927 times
Old 02-17-2018, 04:43:30 PM
Default Magneto Charger Switch
Just bought a heavy duty American Bosch 12 volt mag charger at a local auction. It has no switch or disconnect on it, just battery cables. What would you recommend using for such? Does it need a condenser or capacitor in conjunction with the switch? Bill Klein
Old 02-17-2018, 05:34:35 PM
LCJudge LCJudge is offline
Default Re: mag charger switch
A nice heavy knife switch would work fine for it I’d think.
Tommy Turner
The Following User Says Thank You to LCJudge For This Post:
Old 02-17-2018, 06:31:52 PM
Pat Huebsch Pat Huebsch is offline
I put a push button starter switch on mine.
Pat
The Following User Says Thank You to Pat Huebsch For This Post:
Old 02-17-2018, 10:15:40 PM
John in Maryland's Avatar
John in Maryland John in Maryland is offline
Images: 15
Default Re: Magneto Charger Switch
Mine has push button starter switch with a condenser across the terminals to prevent arcing.
J.I.M.
The Following User Says Thank You to John in Maryland For This Post:
Old 02-18-2018, 12:30:40 AM
stufforbud stufforbud is offline
I've used a knife switch on mine for years and had no trouble.
The Following User Says Thank You to stufforbud For This Post:
Old 02-20-2018, 06:16:47 PM
J.I.M.
Thank you all for responding. Any idea what size the condenser is J.I.M.?
It seems like most of you don't use a condenser. I read where it will do a better charging job with one because the flow thru the coils is interrupted more abruptly. Your thoughts everyone? Bill Klein
Old 02-21-2018, 11:29:34 AM
Images: 15
No, there's no writing on it. Looks like a regular old automotive condenser.
Old 02-21-2018, 02:17:17 PM
Dick Brown Dick Brown is offline
I have used a knife switch for years . Was original to the piece when I got . No problems . Dick
The Following User Says Thank You to Dick Brown For This Post:
Old 02-21-2018, 02:27:23 PM
Exclamation Re: Magneto Charger Switch
A knife switch will work fine, as long as you remember to break the poles rapidly and as far as possible, to prevent flash. you want a heavy switch, double pole to help with the break. otherwise, a starter switch works great. A good auto supply, like NAPA, should be able to supply one.
Old 02-21-2018, 03:04:20 PM
Vanman Vanman is offline
I would be concerned about breakdown of the insulation in the windings of the coils without a condenser...
Most such similar circuits, like the field of motors or generators, employed a resistance that was placed across the field before the supply switch was opened. This would have been accomplished automatically via a switch with an extra contact. As the switch is opened, first the resistor is connected, then the supply is disconnected, leaving the resistor across the field. A make before break arrangement.
Magneto Charger Greg-N-CA Hit & Miss Gas Engine Discussion 2 05-04-2016 10:15:38 PM
Re-purposed a 208 volt, Onan OT float charger from an unusable transfer switch Motorhead Onan Generators 10 02-02-2016 06:26:56 PM
Magneto Charger jdwyer23 Magnetos, Ignition Coils and Spark Plugs 4 12-15-2010 03:02:04 PM
magneto charger Chris J Magnetos, Ignition Coils and Spark Plugs 0 03-13-2007 11:24:30 PM
magneto charger Al Ulibarri Antique Engine Archives 3 03-08-2002 06:09:15 AM
