WICO EK Ignition Lead Contact
this thread has 4 replies and has been viewed 777 times
Old 02-21-2018, 08:41:03 PM
Dsel74 Dsel74 is offline
Default WICO EK Ignition Lead Contact
I have a WICO EK and the Bakelite terminal tower is a blind hole (no thread). I believe this means the spark plug wire had a spring clip soldered to the end?
Can someone please show me a picture of this and point me to any sales sites that would have a suitable one please?
---------- Post added at 11:41:03 AM ---------- Previous post was at 11:29:07 AM ----------
I think this is what I need but is there a specific size?
There are 7 & 9 mm ones here, the solder on type appeal to me more. would these work?
https://enginebarn.myshopify.com/col...wire-terminals
Old 02-21-2018, 09:16:23 PM
Default Re: WICO EK Ignition Lead Contact
You need 7mm's
The Following 2 Users Say Thank You to Pat Barrett For This Post:
Old 02-21-2018, 11:37:56 PM
stufforbud stufforbud is offline
The 7mm ones you show will work fine.
Old 02-22-2018, 01:24:28 AM
cobbadog cobbadog is online now
Hi Dsel74.
John Humphries at Rustic Spares here in NSW has those connectors. Google rustic spares and you will find his website and his email address.
I just replaced all the spark plug leads and new connectors for the ends for one of our tractors. Great product, prices and service.
Old 02-22-2018, 04:28:48 PM
7mm automotive clip should work fine. Any good auto supply should have it. You might find them at a small equipment shop too. The ones you have pictured look like the originals! The pinch ons pictured do not need to be pinched tight. I would strip about 1/4" of the insulation off the end of the wire, and put it thru the center of the clip. Flatten it in a circular pattern, and solder in place. Do not bead up the solder - you want the clip to go into the tower as far as possible. Let cool thoroughly, then lightly compress the clip onto the insulator of the wire. You want the sides of the clip to grip the inside of the tower, so the wire does not fall out.
Wico EK Lead Tower Location rangerfx4man Magnetos, Ignition Coils and Spark Plugs 2 07-07-2014 08:01:04 PM
Tecumseh HM80 Contact Pointless Ignition DTurner Small Air Cooled Gasoline Engines 5 01-12-2011 11:53:05 AM
Switching Lead Out on Wico EK Zira Magnetos, Ignition Coils and Spark Plugs 3 09-22-2009 09:37:09 PM
1 HP Governor weight Ignition contact VicP Maytag Engines and Collectibles 2 02-29-2008 12:43:11 AM
Wico EK magneto lead out tower BobM Magnetos, Ignition Coils and Spark Plugs 5 02-14-2008 05:36:27 PM
