Exhaust Valve Adjustments
this thread has 8 replies and has been viewed 1003 times
Old 02-23-2018, 12:19:07 PM
Geochurchi Geochurchi is offline
Location: Bartlett, New Hampshire, USA / Toronto, Ontario, Canada
Default Exhaust Valve Adjustments
Hi again, I now have a copy of the horizontal timing chart however I need a starting point, how should I start with the valve lifter rod, lets pretend it’s all new with no rod installed.
Geo.
Old 02-23-2018, 12:58:07 PM
Default Re: Exhaust valve adjustments
What engine?
Old 02-23-2018, 01:00:13 PM
Sorry, it’s a FM 1 1/2 HP Z
Geo
Old 02-28-2018, 01:50:37 PM
Still can’t get the exhaust valve adjusted,it states that the crank rod should be facing up, I assume that means that the nuts on the rod cap should be parallel with the base, what affect does the governor have on the rod adjustment?
Geo
Old 02-28-2018, 02:32:44 PM
Exclamation Re: Exhaust valve adjustments
There is no set clearance for the exhaust valve rocker. The valve opens about 20 degrees before BDC on the power stroke, and is closed at TDC intake. Holding the intake valve open, turn the engine BACKWARDS (counter clockwise from the cam/mag side) until the engine reaches TDC, between the exhaust and intake stroke. The valve should just close at the TDC point, if not slightly after (before TDC). Once you have that right, the second point should be OK, unless your cam timing is off. Turning the engine CLOCKWISE from the mag /cam side, the valve should open at roughly the 20 degree position, late in the power stroke. The governor has nothing to do with the valve operation, only throttle control
Old 03-01-2018, 09:06:50 AM
Thanks I’ll give that a try,what is the best way to determine the 20* angle?
Geo
Old 03-01-2018, 09:29:24 AM
Google degree wheel, images, find one that opens clearly and print it, paste it to cardboard, cut center to slip over crankshaft. Make a pointer and you can follow the valve opening-closing. This is really too technical but it will show you what's going on. It will run if it's close.
Old 03-01-2018, 02:00:58 PM
Default Re: Exhaust Valve Adjustments
The opening point is not too critical, the close point is. The valve must be closed at TDC between strokes. The valve should open about 1/4" if not a little more, at full open if I remember right, the F/M Zs had a spring on the rocker that kept it in contact with the exhaust pushrod. it helped keep the pushrod against the cam follower.
Old 03-07-2018, 10:24:03 PM
Hi All, I believe I have the exhaust valve set however I think there is still a problem in that the push rod is adjusted out to full length and seems sloppy,almost like it is to short, also when I spin the engine over it will pop once and not continue to fire.
Geo
Exhaust Valve Box Keven Withers Hit & Miss Gas Engine Discussion 5 01-24-2013 08:09:21 PM
1-1/2 HP IHC M Exhaust Valve John Cunningham Hit & Miss Gas Engine Discussion 6 07-14-2009 06:38:10 AM
Stuck Exhaust Valve Tom Herd Hit & Miss Gas Engine Discussion 11 02-08-2009 01:06:15 PM
H&M exhaust valve clearance gafisk Hit & Miss Gas Engine Discussion 1 12-14-2007 03:01:20 AM
