Allen Magneto Testing Station
this thread has 4 replies and has been viewed 1059 times
Old 03-09-2018, 05:27:05 PM
Brian.P's Avatar
Brian.P Brian.P is offline
Default Allen Magneto Testing Station
I thought I would show it working with the mag
sure is noisy on the film compared to running it in the room
it' not 100 percent right but think it's close and not bad for 80 plus years old
the noise is the coupler and advance this is one heavy unit never tried anything else on it
the mag was in it when I bought it has lot of different adapters
https://youtu.be/x6L7jvyuK5w
ID:	305032   Click image for larger version
The Following 7 Users Say Thank You to Brian.P For This Post:
Old 03-10-2018, 01:02:15 AM
cobbadog cobbadog is offline
Default Re: Allen Magneto Testing Station
What a lovely display that would make at a Rally. Thanks for posting.
I wonder what is making the noise, the coupling itself?
Old 03-10-2018, 07:06:30 AM
Elden DuRand's Avatar
I like it! From the looks of it, you can also test generators.
The noise could be a worn/dry bearing.
[SIGPIC][/SIGPIC]
Take care - Elden
http://www.eldensengines.com
Old 03-10-2018, 09:39:31 AM
Brian.P's Avatar
Elden
I took the mag off the motor runs nice a little noise from the rpm cable witch is normal
the hub of the mag has a big spring init makes a loud click plus the 2 pin couple must transfer noise
looks like thee is a place to place a buzz coil for testing there are 4 heavy casing brackets for 2 shelf to place batteries on for other tests
2 guys have trouble moving this the clear plastic disk has been changes it is a timming wheel
Old 03-10-2018, 01:02:42 PM
Vanman Vanman is offline
I have one of these of a different make, which I cannot recall at the moment. Nowhere near as nice as yours, but still pretty neat.
LOVE the GE variable repulsion motors! And that looks like either an original or period lightbulb on yours. Really love that!
Allen Magneto Test Bench Question iowairongirl Magnetos, Ignition Coils and Spark Plugs 2 07-06-2015 09:29:30 AM
Allen magneto test bench Brian.P Hit & Miss Gas Engine Discussion 1 05-30-2015 10:12:25 PM
Allen 157 Magneto checker Molinegb Magnetos, Ignition Coils and Spark Plugs 4 02-04-2015 11:32:34 AM
allen magneto tester J Ware Magnetos, Ignition Coils and Spark Plugs 9 11-25-2014 12:18:18 PM
testing the magneto stevenkd5017 Hit & Miss Gas Engine Discussion 6 04-09-2012 09:39:11 PM
