Long 1/2 Inch Spark Plug Type Identify
this thread has 8 replies and has been viewed 971 times
Old 03-14-2018, 03:04:15 PM
Daan Daan is offline
Default Long 1/2 Inch Spark Plug Type Identify
Hey
I need a long 1/2 inch spark plug with the same thread as a Champion X.
On YouTube I saw a video with a long one, but I can't identify it. Does someone know the type?
The link of the Video is shown below
https://youtu.be/vkECxLcLR98
Thanks a lot
Old 03-14-2018, 03:39:47 PM
Norm Johnston Norm Johnston is offline
Default Re: Long 1/2 Inch spark plug type identify
The plug in the video appears to be a Champion 32, if so it is an extremely hard spark plug to find. A few years ago I was lucky enough to get a set for my BIG FOUR tractor and it now starts and runs so much better with them.
I believe it is used mostly in engines of the headless design with low compression and a large space between piston top and plug mounting hence the long reach.
Old 03-14-2018, 04:02:22 PM
Thanks for the reaction.
I need one of these for my engine, that is a copied beeman. First it has a Champion A25 but it didn't run wel and I made a longer spark plug and it fired right up, it is only not made for hundred hours .
Is there a remake from such type spark plug?
Or where can I buy it?
Old 03-15-2018, 07:54:39 AM
JBS JBS is offline
Wink Re: Long 1/2 Inch Spark Plug Type Identify
Is the spark plug for a model t the correct length.
---------- Post added at 07:54:39 AM ---------- Previous post was at 07:51:56 AM ----------
Originally Posted by daan View Post
hey
i need a long 1/2 inch spark plug with the same thread as a champion x.
On youtube i saw a video with a long one, but i can't identify it. Does someone know the type?
The link of the video is shown below
https://youtu.be/vkecxlclr98
thanks a lot
would a spark plug for a model t ford work.
Old 03-15-2018, 08:49:02 PM
Default Re: Long 1/2 Inch Spark Plug Type Identify
I would need to see the head design to have any idea. I was using Model T plugs in my BIG FOUR and yes they worked but quickly became fouled with carbon resulting in erratic running, loss of power and hard starting. The main problem being that the T model plugs did not reach far enough down into the compressed air /fuel mixture resulting in only partial firing and consequencial plug fouling. Have you a picture of the Head showing the internal position of the plug ?
Old 03-16-2018, 03:13:34 AM
Here is a picture from the head.
The spark plug is 0.5 inch to short.
It is a Champion X.
Old 03-16-2018, 08:41:18 AM
sparky49 sparky49 is offline
I have some of the very long reach 1/2" pipe thread plugs for sale, Champion 32 type and some Splitdorf made plugs of the same type. Advise if interested, Lanny Baron, 516-426-1098
Old 03-16-2018, 12:10:06 PM
There is only a little issue, I live in the Netherlands.
Old 03-16-2018, 01:32:41 PM
Exclamation Re: Long 1/2 Inch Spark Plug Type Identify
Look on Ebay for Chamion #34 Gas Engine Special or Maytag pipe based spark plug (for uprights, models 82 and 92 hit and miss engines). Same plug, but one has the a Maytag name on it. These plugs are hotter than the 32 and less expensive. They won't foul as quickly as the X, if at all
18mm long reach spark plug George Best Hit & Miss Gas Engine Discussion 8 05-23-2017 04:58:19 PM
3/4" non long reach spark plug? Scott Hosack Hit & Miss Gas Engine Discussion 11 04-07-2016 10:32:00 PM
Splitdorf green hexagon spark plug xtra long Dennis Gooch Magnetos, Ignition Coils and Spark Plugs 0 07-14-2015 08:03:08 PM
3/4 inch pipe thread spark plug REB37E Magnetos, Ignition Coils and Spark Plugs 10 07-23-2014 08:42:16 AM
Long reach spark plug tom weatherford Antique Engine Archives 6 06-21-2003 03:48:19 PM
