Associated Hired Man Magneto Testing
this thread has 1 replies and has been viewed 625 times
Old 03-15-2018, 10:38:02 PM
cdn97 cdn97 is offline
Default Associated Hired Man Magneto Testing
How can I test my magneto? Also, any tips on how to make it perform better? Should the rust be removed? Can the magnets be painted? Any info is appreciated. Had the engine for a while and finally getting around to clean it up a bit. Want to get it running as good as I can.
Old 03-17-2018, 10:36:35 PM
cobbadog cobbadog is offline
Default Re: Associated Hired Man magneto testing
The most important things to have is a good coil, condensor and magnetism. Clean is good and paint on the outside will not hurt. Magneto must be able to make a good metal to metal contact for a good earth for good performance. Good points and correct gap helps a lot too.
Magneto Testing Meter? Tom Herd Magnetos, Ignition Coils and Spark Plugs 4 03-04-2013 07:50:53 PM
testing the magneto stevenkd5017 Hit & Miss Gas Engine Discussion 6 04-09-2012 09:39:11 PM
Testing an AEC Type R magneto? GlennW Magnetos, Ignition Coils and Spark Plugs 2 11-15-2010 08:18:14 PM
CCK magneto coil testing Ray Griffiths Onan Generators 4 12-04-2008 04:10:32 PM
Hired Man magneto magnet needs a charge. Buck420 Hit & Miss Gas Engine Discussion 1 01-29-2005 01:45:16 PM
