Cushman WICO EK
this thread has 6 replies and has been viewed 816 times
Old 03-17-2018, 03:46:06 PM
Olf20 Olf20 is offline
eMail NOT Working
Default Cushman WICO EK
We have a new to us Cushman with the Wico
EK mag. The spring that goes from the
coil to the bakelite in the mag cover does not
line up. If you remove the bakelite the solder
lug on the coil is off to one side of the center
of the hole.
Any thoughts?
Thanks for any help!
olf20 / Bob
Old 03-17-2018, 04:16:57 PM
Default Re: Cushman WICO EK
of the hole.
Any thoughts?
olf20 / Bob
Try turning the cover around.
Jim
Old 03-17-2018, 04:29:07 PM
eMail NOT Working
Did that but the hole in the cover is still off
center and the wire is in the road of the
advance mech.
Thanks for the reply.
olf20 / Bob
Old 03-17-2018, 05:23:31 PM
mmcdonald mmcdonald is offline
The coil most likely rotated on the core over time. If you can gently turn it by hand you might be able to position correctly and then carefully lock it in place with some plastic or wood pushed in between the core and the coil ID. If the coil doesn't want to turn you'll have to slide it off and reinstall in correct position and then again lock it in place with plastic/wood etc. Good luck.
info@mcdonaldcarb.com
Old 03-17-2018, 06:26:50 PM
eMail NOT Working
Thanks! I'll do that.
Hope to get the old girl running
soon.
Thanks again.
olf20 / Bob
Old 03-19-2018, 03:54:30 PM
Button rotation on the EKs is common. If the outer cover is torn or deformed, you probably will need to replace the coils. Don't try to re-solder it, you will ruin the secondaries (if not shot already). Check that the one under the copper ground spring on the other side, is also in alignment. There ia also a small spring that attaches the secondary windings between the 2 coils. Be sure it is in place also.
Old 03-19-2018, 04:45:44 PM
eMail NOT Working
The outer cover is in perfect condition. I will look at the
spring between the two in the morning.
Thanks for the advise!
olf20 / Bob
4HP Cushman w/Wico Magneto sjaysop Hit & Miss Gas Engine Discussion 2 08-02-2015 01:00:18 AM
Wico EK on a Cushman Cub R-14 shattercane Hit & Miss Gas Engine Discussion 3 02-17-2014 11:30:32 AM
Wico EK on Cushman Cub Zira Hit & Miss Gas Engine Discussion 9 05-24-2010 11:59:12 AM
Old Cushman Binder Engine, New Cushman Owner Short Circuit Hit & Miss Gas Engine Discussion 3 05-19-2010 09:06:38 PM
Cushman 4 hp. with Wico EK Larry K Hit & Miss Gas Engine Discussion 7 04-16-2006 09:40:36 AM
