Running 12 Volts Into 24 Volt Starter
this thread has 4 replies and has been viewed 596 times
Old 03-17-2018, 06:03:59 PM
Brian.P's Avatar
Brian.P Brian.P is offline
Default Running 12 Volts Into 24 Volt Starter
I was looking at the starter someone put on a 4 hp Lister diesel engine
I bought last year with a gen on it belt driven
it's been on for years not sure how often it was used .the engine starts with the crank I was going to add a rubber disk to it to starter to start engines .it has a 12 spine shaft not common it seems for a 5/8 to 11/16 shaft
I happen to look at the tag today and saw it was 24 volts
looking a Pesco Products co it seems they were aircraft any idea what it would have been used on
would running it on 12 volts have done damage seems to run strong the few times I started it last year
ID:	305801   Click image for larger version
Old 03-17-2018, 06:22:35 PM
Power Power is offline
Default Re: Running 12 volts into 24 volt starter
In my opinion, 12 volts would not hurt it, unless starter could not roll engine and was held energized (locked rotor) for a time.
The Following 2 Users Say Thank You to Power For This Post:
Old 03-17-2018, 06:25:38 PM
Vanman Vanman is offline
All other things being equal, it will merely run at ~1/2 speed. If that is still sufficient to start the engine, it ought to work well.
Old 03-17-2018, 06:31:11 PM
Brian.P's Avatar
it would be better at half speed as the tag shows 4000
would the same battery drain faster than if it was a 12 volt starter
thanks
Old 03-17-2018, 08:03:34 PM
Default Re: Running 12 Volts Into 24 Volt Starter
Battery drain (again, all things being equal) will be directly related to cranking speed.
12 volt starter for an 032 engine Tom Hook Military MEP and Aircraft Gen-Sets 28 11-25-2013 07:36:16 PM
12 volt DC starter direction change Dwayne Fuller Generators & Electric Motors General Discussion 12 08-12-2010 08:22:34 AM
Lincoln mod225-3as change starter to 12 volts Jerry Scholton Welding Shop 2 05-05-2010 06:12:36 PM
Delco Remy Volt. Reg. & Starter/Gen. Jim Nixon Garden Tractors and Mowers 1 08-21-2008 10:00:33 AM
Onan BGEF runs 230 volts when its a 120 volt unit. transambandit77 Onan Generators 3 04-07-2008 03:18:27 PM
