Telephone Magneto?
this thread has 10 replies and has been viewed 1101 times
Old 03-17-2018, 10:05:21 PM
SteveK SteveK is offline
Default Telephone Magneto?
Anyone ever tried running an engine with a telephone magneto? I bought one at an antique store for a dollar and was wondering what to do with it.
I forget how many volts but I know it has output and makes AC. I was thinking of trying it on a low tension ignition engine after starting on battery switch to magneto. Ignitor points are open until it trips. I am not sure if the AC out put will work with a coil though as the magnetic field changes back and forth but then again it only will have a closed circuit for an instance.
Thoughts?
On the level
Old 03-17-2018, 10:26:55 PM
Default Re: telephone magneto?
Telephone magnetos develop about 90VAC ring voltage, but maybe could be used to drive a step up transformer. Like maybe a flyback transformer off an old CRT monitor.
Doc
Old 03-18-2018, 05:17:48 AM
Elden DuRand's Avatar
Images: 11
Doc:
SteveK was talking about an ignitor engine. It could possibly work except I would be leery of spinning it through the gears of the crank. It would spin really, really fast and the bearings and windings would probably grenade.
Then, with the high RPM, the voltage could rise to the point where the insulation in the windings fails.
Good thought, good idea but maybe a nice shelf would be the best place for the magneto.
[SIGPIC][/SIGPIC]
Take care - Elden
http://www.eldensengines.com
Old 03-18-2018, 06:55:46 AM
oldgoat oldgoat is offline
Email NOT Working
90 to 100 v ac but only milliamps of current don't think it will suit the purpose
Old 03-18-2018, 05:06:40 PM
Default Re: Telephone Magneto?
Thanks for the replies! I understand what you mean Elden
I was going to go direct to the armature to avoid a grenade scenario
90V seems tall to run through a low tension coil at any rate. On the shelf it will stay for now.
On the level
Old 03-18-2018, 06:06:51 PM
I've heard stories about people using them to "Go fishing" and shocking fish into floating up to the top to be netted up. Illegal here. Called "Telephoning"
Old 03-18-2018, 06:30:15 PM
DustyBar DustyBar is offline
I always thought DuPont spinners were more fun.
The Following User Says Thank You to DustyBar For This Post:
Old 03-18-2018, 06:45:22 PM
Images: 11
Steve:
When a low tension magneto is used, an induction coil is not needed. The inductance of the magneto coils does the job.
[SIGPIC][/SIGPIC]
Take care - Elden
Old 03-18-2018, 09:55:44 PM
Ok! had not thought about that. I was assuming the mag output would be too low and need the coil. Glad you pointed that out.
On a side note some quick math, flywheel 24 inches, crank gear on mag 3 inches armature gear 1 inch. At 400 engine rpms that would spin that baby around 9000 rpms!! You dont think it would hold up? What a sight!!
I took a starter off a car once that had stayed engaged. It appeared that somewhere between first and second gear the copper windings met up with the field magnets! I must have poured 2 cups of dust out of that starter housing!
On the level
Old 03-19-2018, 06:35:47 AM
Email NOT Working
I have come across a few telephone magneto's where they turned them with a 32v drill probably 500 rpm which meant the armatures were doing about 3000 rpm . Certainly threw all the winding out and chopped up on the pole pieces.
The Following User Says Thank You to oldgoat For This Post:
Old 03-19-2018, 03:28:52 PM
The phone mag will not stand up to more than 3 or 4 hundred RPM. I had one belted to a model steam engine, and used it to light 1.5 volt flashlight bulbs. About 4 was all it could handle. It would light a small flourescent tube though, albeit dimly. (6" tube)
Telephone magneto for ignitor? David Hughes Magnetos, Ignition Coils and Spark Plugs 7 11-08-2014 01:46:08 PM
Question about Telephone Magnetos? Jasper Odell Magnetos, Ignition Coils and Spark Plugs 7 05-26-2009 07:41:41 PM
Miniature magneto & Telephone magnetos Ronald E. McClellan Hit & Miss Gas Engine Discussion 2 04-05-2007 06:03:12 PM
Telephone Outage - ISP Harry Computer, Camera and ISP Problems 1 11-07-2006 12:07:13 PM
