Bosch BAE 1 19 Magneto, Spark on Test Bench but not on Engine
this thread has 6 replies and has been viewed 773 times
Old 03-19-2018, 04:24:11 PM
Charlie Lindberg Charlie Lindberg is offline
Default Bosch BAE 1 19 Magneto, Spark on Test Bench but not on Engine
Rebuilt Bosch mag makes great spark when held in hand, and when set on a steel table with bronze drive gear flipped around.
When attached to engine, no spark. Appears to be shorted.
Tried to isolate gear from the output shaft with film plastic and a Teflon washer.
Meter indicated success, but still no spark when attached to engine.
Voltage may have broken down the diaelectric? Make a delron gear?
Have a spare Bosch mag which also acts the same.
Engine, Novo configured with the spare mag reported ran in the past.
What to try next, ?
Fritz
Old 03-19-2018, 04:32:07 PM
stufforbud stufforbud is offline
Default Re: Bosch BAE 1 19 magneto, spark on test bench but not on engine
Make sure you have a really good ground between mag body and mount.
Old 03-20-2018, 10:35:28 AM
Mitch Malcolm Mitch Malcolm is offline
Banner Sponsor
Great spark ?? How far a air gap will it jump from the plug wire back to the mag body.. nothing short of 1/4 inch will do
Old 03-20-2018, 11:15:44 AM
What to try next, ?
Fritz
You need to take into consideration the difference in speeds at which you are turning the mag. When you "give it a flip" on the bench, you are likely turning it several hundred rpm's. Assuming there is no impulse coupler on the engine, at cranking speed the mag is probably turning less than 100 rpm's especially when the engine goes over top dead center on compression.
What model Novo do you have?
The Following User Says Thank You to Kirk Taylor For This Post:
Old 03-20-2018, 06:41:58 PM
One eight to three sixteenth
---------- Post added at 03:41:58 PM ---------- Previous post was at 03:06:44 PM ----------
One eighth to three sixteenths
Old 03-20-2018, 06:43:09 PM
Default Re: Bosch BAE 1 19 Magneto, Spark on Test Bench but not on Engine
You need a minimum of a 1/4' at LOW speed. When installed on the engine, take a look at how fast the mag is turning. You may have to spin the engine with a crank to get the speed you need to make spark!
Old 03-22-2018, 07:30:44 PM
Andrew Mackey
Will try spinning faster, need to make more room,
C
1920(?) Jos. Weidenoff Magneto & Generator Test Bench Greg-N-CA Magnetos, Ignition Coils and Spark Plugs 3 04-27-2016 11:20:35 PM
Allen Magneto Test Bench Question iowairongirl Magnetos, Ignition Coils and Spark Plugs 2 07-06-2015 09:29:30 AM
Allen magneto test bench Brian.P Antique Gas Engine Discussion 1 05-30-2015 10:12:25 PM
American Bosch magneto bench tester? andyeha Magnetos, Ignition Coils and Spark Plugs 1 05-08-2014 09:08:27 AM
Wiedenhoff Magneto/starter/generator test bench Chris Haynes Magnetos, Ignition Coils and Spark Plugs 0 12-28-2009 01:26:17 AM
