Weak Spark RV1 Magneto Fairbanks Morse
this thread has 5 replies and has been viewed 1042 times
Old 03-25-2018, 09:27:23 AM
Daan Daan is offline
Default Weak Spark RV1 Magneto Fairbanks Morse
Hello
I have an old Fairbanks Morse RV1 magneto and it has a very weak spark, if I put the drill on the mag and make sure that the spark plug gap very close is, then there is spark.
If i turn it with my hand there is no spark but if I touch the connector of the coil then I get a little shock.
I tried already another condenser (o,22 uF) and some new points, but there is no diffrence.
Does anyone know what is wrong?
Old 03-25-2018, 04:36:48 PM
SteveK SteveK is offline
Default Re: Weak Spark RV1 Magneto Fairbanks Morse
Magnet may need recharging.
On the level
The Following User Says Thank You to SteveK For This Post:
Old 03-26-2018, 01:45:59 AM
cobbadog cobbadog is offline
Recharge the magnets then if it is still no good looks like a coil.
Old 03-26-2018, 09:19:08 AM
Thank's for the reactions.
What is the easiest way to make a magnet charger?
Old 03-26-2018, 01:57:30 PM
There are several threads on magnet chargers. Have a look in the Stak Archives.
Old 03-27-2018, 04:49:23 PM
Scotty 2 Scotty 2 is offline
Hello all
Before making a charger how about some diagnostics?
Do you have a mulitimeter Daan? If so measure the resistance of the high tension side of the coil and also the low tension side of the coil.
Was the condenser you tried known to be good? They do break down over time.
Are the points clean and set correctly?
Cheers Scott
The Following User Says Thank You to Scotty 2 For This Post:
Pe-75 weak spark csareb Small Air Cooled Gasoline Engines 4 03-07-2017 06:38:45 PM
Weak looking spark? Jim M. Magnetos, Ignition Coils and Spark Plugs 5 04-02-2014 04:05:37 PM
Erratic spark -Fairbanks Magneto petryss Magnetos, Ignition Coils and Spark Plugs 4 02-19-2010 09:42:17 PM
Fairbanks Morse ZC 3hp Magneto - no spark alphahercules Magnetos, Ignition Coils and Spark Plugs 2 05-04-2008 03:06:16 PM
Ihc M 3hp weak spark jmsolomonson Hit & Miss Gas Engine Discussion 7 04-10-2008 10:05:19 AM
