8 Tooth Sprocket?
this thread has 6 replies and has been viewed 710 times
Old 03-31-2018, 02:26:53 AM
friday friday is offline
Default 8 Tooth Sprocket?
anyone seen one of these sprockets before ?
8 tooth dia 1-1/2 across tips
width is 3/8 at hub
taper is 7/16 to 1/2 (1:10)
key is 3/32
pitch is 1/2"
typical taper fits straight on a splitdorf magneto shaft but I would say this is a dynamo chain drive
Miller ? BTH ? Lucas ?
cheers
Name:	8 t key.JPG
Old 03-31-2018, 02:53:27 AM
Default Re: 8 tooth sprocket ?
Sure, (I think). It looks very similar to drive sprockets used on electric scooters and pocket bikes. Although they usually have D sided, double flat side or spline drive hubs. Might check to see if pitch fits a bicycle chain (#25).
Doc
Old 03-31-2018, 03:52:41 PM
Default Re: 8 Tooth Sprocket?
being 1/2 pitch , 1/4 roller , its 420 or so chain .
but having a taper and key Id expect it to be driven gear not a power gear .
maybe a Indian papoose
Old 03-31-2018, 04:31:12 PM
The teeth look very narrow.
I'm thinking #43 chain which has 1/8" wide rollers.
#41 chain has 1/4" wide rollers.
#420 chain is extended pitch chain which has one roller every other tooth.
Old 03-31-2018, 05:12:45 PM
Pat Barrett Pat Barrett is online now
It somewhat resembles a drive sprocket used on some gas powered reel mowers
Old 03-31-2018, 07:40:09 PM
sorry bout that , I mean 1/4 diameter roller not width .
I see there are dynamo specific type skinny chains .
I was just looking at a chain diagram to get the #420 motorcycle reference .
I dont know how old this is , theres 3 in a zip packet which came with some Indian parts ....which doesnt mean much.
I was thinking chain saw but then theyre different sprocket again
Old 03-31-2018, 08:32:49 PM
Craig Gillingham Craig Gillingham is offline
The 1:10 taper matches a standard magneto taper, and I think at least the Lucas generators used the same taper. As for what used a 8 tooth sprocket? I've no idea.
Unknown Drive Sprocket Mike G Garden Tractors and Mowers 1 10-01-2017 02:02:44 PM
McCormick Deering 1 1/2 M Sprocket rickinmemphis Hit & Miss Gas Engine Discussion 7 06-05-2014 07:41:23 AM
B&S Starter with Sprocket!? Gravely? cheddarhead Garden Tractors and Mowers 2 02-20-2011 08:08:25 PM
Lucas Magneto Sprocket AUSDOK Magnetos, Ignition Coils and Spark Plugs 3 02-18-2009 08:35:06 AM
removing stuck sprocket from briggs 3 hp Jamesk Hit & Miss Gas Engine Discussion 4 05-01-2007 06:14:00 PM
