Wico AH magneto rebuild
this thread has 5 replies and has been viewed 487 times
Old 08-11-2019, 07:03:54 PM
Voltar1 Voltar1 is offline
Default Wico AH magneto rebuild
Hi fellas, new here with some questions wrt the mag from my IHC LA engine.
I would like to know how the points backing plate is removed from the mag?
Something behind it is rubbing on the rotor which I presume comes out the back?
Also in the market for a set of points and coil cover.
Thanks in advance
Walter from Alberta, Canada eh!
Old 08-11-2019, 10:08:25 PM
Gilles Marcil Gilles Marcil is offline
Default Re: Wico AH magneto rebuild
Thanks in advance
Adrian magneto is your best help in Western Canada
The Following User Says Thank You to Gilles Marcil For This Post:
Old 08-11-2019, 11:43:52 PM
Thank you Gilles,
Will call him tomorrow
Old 08-12-2019, 06:31:11 PM
Called Rudy at Adrian's Magneto Repair. Chatted a bit then ordered the set of points I need. The point cup is seized up or frozen in place on mine so will avoid removing it if possible.
Old 08-13-2019, 04:01:40 PM
barry ayres barry ayres is offline
i think you leave that plate in place and take the rotor out from the front.
Old 08-18-2019, 11:17:04 PM
Thank you Barry. Can leave the magneto alone for now. Waiting on the points which should be all I need.
Wico EK Magneto Rebuild Kit JeffR Smokstak Down Under 5 03-19-2018 08:10:53 AM
Wico Ek Magneto rebuild Hughesy Hit & Miss Gas Engine Discussion 9 05-22-2012 07:39:39 PM
WICO EK magneto coil rebuild Chad Magnetos, Ignition Coils and Spark Plugs 2 08-25-2008 02:25:21 PM
Magneto rebuild and WICO EK parts question Jebaroni Magnetos, Ignition Coils and Spark Plugs 2 01-24-2006 11:26:35 PM
Wico Rebuild Kits B.Brod Antique Engine Archives 6 07-08-2002 09:33:32 AM
