Galloway Mixer needle valve
this thread has 3 replies and has been viewed 1536 times
Old 08-07-2008, 09:43:45 AM
TomAnderson TomAnderson is offline
Default Galloway Mixer needle valve
I need to find or fabricate a needle valve for this mixer from a 6 HP Galloway. This is not an early engine and I think it may be from the last years of production. Can anyone provide a photo or a drawing ? Can a valve from a Lunkenhiemer be used ? I would appreciate any help as this is the last thing I need to complete this engine. Thanks.
Old 08-07-2008, 06:12:51 PM
John Drabik's Avatar
John Drabik John Drabik is offline
Default Re: Galloway Mixer needle valve
I dont have a valve for you but before you buy or make one check the threads per inch and stem size that you will need. Many of the engines I have worked on had uncommon tpi`s (threads per inch). 1/4- 18 tpi as opposed to the nowadays common1/4-20 etc.
Old 08-07-2008, 06:20:31 PM
KenK KenK is offline
Hi, Presuming you have a Galloway with the rounded hopper and oval water opening, a lunkenheimer will certainly work, although not correct. These engines used a variation of the Lunkenheimer mixer. No name, possibly their own make. No pictures but look on cover of Wendel's yellow book, inside under Galloway also, if you have one. Sure someone will post a picture.
Old 08-07-2008, 08:14:27 PM
Joseph Cissell Joseph Cissell is offline
Tom, Send me and email and I will see if I can help you out on your needle valve. My email; mrhanney@wk.net Thanks, Joe
Maytag 92 needle valve Clarence McGehee Maytag Engines and Collectibles 3 04-27-2008 09:00:54 AM
IHC m needle valve knobs Scott Hit & Miss Gas Engine Discussion 3 03-19-2008 02:27:02 AM
Jam Nut on Needle Valve? Baggsy-Wy Antique Engine Archives 3 11-14-2003 12:56:54 PM
Needle valve Alan James Antique Engine Archives 0 02-06-2003 12:38:09 PM
Bent Needle Valve - How Do I Fix? Paul Maples Antique Engine Archives 7 08-29-2000 07:04:55 PM
