Mogul Magneto
this thread has 5 replies and has been viewed 1080 times
Old 04-11-2018, 09:58:09 AM
JWithers JWithers is offline
Default Mogul Magneto
I have a 12hp IHC Mogul. The other day I removed the whole magneto from the engine and brought it to a friend with a magneto charger. He suspended the mag from a rope over the charger and we watched in amazement as my mag stopped 90 degrees off of where it should have stopped when locating the poles.
We also charged the mag for a 35hp Ingeco. Same process to locate the poles but that mag oriented it's self properly and it was charged.
This was the first time I have ever seen this process but my friend has done this many times. He said he had never seen a mag stop 90 degrees off like mine did and refused to go any further. And I was ok with that.
So here are my questions, what is going on with my mag? How do I correct this?
Jeremy Withers
Old 04-11-2018, 02:06:46 PM
LCJudge LCJudge is offline
Default Re: Mogul magneto
Made in China?.....
Tommy Turner
The Following 2 Users Say Thank You to LCJudge For This Post:
Old 05-21-2018, 09:35:06 PM
D Reachard D Reachard is offline
Originally Posted by LCJudge View Post
Made in China?.....
If it has two magnets???? on it ,Maybe the second one was put on N to S instead of both North Poles together????????
The Following User Says Thank You to D Reachard For This Post:
Old 05-22-2018, 04:12:01 PM
Banner Sponsor
Default Re: Mogul Magneto
A compass works great for finding the polarity. Also helpful to move around magneto parts to determine where poles are and what polarity. I've seen all kinds of odd things. One Wico X mag last year, the two "poles" on the magnet rotor, one should be south one should be north. Both "poles" were north and the actual shaft through the center was south.
info@mcdonaldcarb.com
The Following User Says Thank You to mmcdonald For This Post:
Old 05-22-2018, 09:21:28 PM
I ended up buying an IHC low tension magneto book. In it it says the magnets should have punch marks on them for orientation. I took the band off and they are in the correct positions. When we had this problem a compass was telling us they were maybe not right. Now when i use a compass there is distinctly a north and a south. I believe what happened is i had 3 mags in my backseat kind of in a pile which i have since read is a no no. So i think that may have temporarily confused the magnets.
I've already put the mag back on my engine and ran it with out having it charged. The magnets have what feel like no pull when i touch them with any steel. I dont know anything about mags really so dont know how much pull it should have when you touch something to it or if all the magnetic power is already directed into the mag or maybe i shouldn't be messing with it at all. Im also sure opinions on that will vary.
So now the mag is back on the engine and the engine does run. What started all this is the engine is hard starting. Ive had the igniter out and cleaned. Last year I was starting on battery an coil then switching it back to the mag. Yes being very careful to ground the lead from the mag to the mag and never have power running to the mag from the coil and battery.
Jeremy Withers
Old 05-23-2018, 02:18:43 AM
cobbadog cobbadog is offline
The magnets should have quite a bit of 'pull' on them. A small screwdriver should be able to be held against the magnets but not for a long time. You should also feel the pull of the magnets as you rotate the magneto, if not it's back to the maggy shop to rectify the problem.
Magneto for Mogul 10-20 colo Magnetos, Ignition Coils and Spark Plugs 3 04-13-2018 03:01:08 PM
1HP Mogul Magneto and Gear Mike Antique Gas Engine Discussion 3 11-03-2008 08:14:55 PM
1 HP Mogul Magneto Roger Eldred Antique Gas Engine Discussion 3 07-08-2007 09:50:18 PM
1 HP Mogul Magneto TomT Antique Gas Engine Discussion 3 05-18-2007 09:44:11 PM
Magneto Timing 1 hp Mogul oldironcollector Antique Gas Engine Discussion 3 11-10-2006 12:03:17 AM
