Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Unidentified Engines
Unidentified Engines Post your photos and questions about your unknown engine and look for answers here.
Help ID this Mystery Engine?
this thread has 7 replies and has been viewed 1908 times
Old 04-19-2018, 08:56:59 AM
Qurple Qurple is offline
Photo Help ID this Mystery Engine?
Pics linked below. I picked this engine up at my uncle's auction a few weeks ago. There is a brass tag but it is almost completely worn away. Don't have a lot of experience with these so really no idea what else to look for in terms of ID.
Mag side
Pulley side
Governor
Head
Old 04-19-2018, 09:09:14 AM
Jason Dahm Jason Dahm is offline
Default Re: Help ID this mystery engine?
Looks like a 2 1/2hp Economy built by Hercules. Jason
The Following User Says Thank You to Jason Dahm For This Post:
Old 04-19-2018, 09:50:30 AM
Agreed.
The tag didn't have the name on it. If it's legible enough, the HP should be "2½E" with a six digit serial number. It has the newer style flywheels which dates it to 1917 or after; and a Webster mag which was discontinued ~1922.
Old 04-19-2018, 12:12:27 PM
Default Re: Help ID this Mystery Engine?
Mag side
...and PLEASE remove the bolt sticking out of the flywheel spoke before someone gets hurt.
Old 04-19-2018, 06:39:50 PM
LCJudge LCJudge is offline
Agreed Kirk!! I'm sure someone put it on there to crank it but that is DANGEROUS. Someone could get seriously injured. Get that off ASAP.
Tommy Turner
The Following User Says Thank You to LCJudge For This Post:
Old 04-29-2018, 01:30:40 PM
ScooterBob ScooterBob is offline
Here's a lot of info about your engine...
http://herculesengines.com/hercules/default.htm
If you need help or pointers getting it going, I'm up the road to the NE about 50 minutes from you. Send me a private message if you'd like to discuss anything about it.
The Following User Says Thank You to ScooterBob For This Post:
Old 05-07-2018, 10:00:54 AM
Wow you guys are good. I could just make out the 2 1/2 E on the brass tag. I will definitely take out that bolt on the flywheel. When dad saw that he called it a "suicide crank" . We have a little engine/tractor show here in July maybe I can get it going by then!
Old 05-17-2018, 04:13:10 PM
If set up right, and if the engine has good compression, you should be able to start it without a crank! If you can read the engine serial number, post and we can date the engine for you!
V-12 Mystery Engine JIMnWV Antique Autos and Trucks 16 12-22-2014 06:05:29 PM
Another Mystery Engine??? Denis Rouleau Antique Gas Engine Discussion 13 06-18-2007 11:27:20 PM
Mystery engine Jan Arne Midtsæter Antique Gas Engine Discussion 10 08-09-2006 07:56:27 PM
Mystery Engine Patrick M Livingstone Antique Engine Archives 4 12-09-2003 06:46:03 PM
Mystery engine in Oz Patrick M Livingstone Antique Engine Archives 5 09-29-2002 12:31:47 PM
