Wisconsin Engines
Wisconsin VH4D Charging Problem
this thread has 2 replies and has been viewed 956 times
Old 06-27-2018, 12:27:49 PM
rwk rwk is offline
Default Wisconsin VH4D Charging Problem
Hello
New here and have a VH4D, it appears to be a 1980.
Motor runs well, but not charging, (25 amp stator) would like to convert to a single regulator/rectifier, seems originals are not available . Can anyone help with a conversion reg/rectifier part number, and how to?.
Where is a good source of tune up and maintenance parts.
Also does anyone have used shroud parts? looking for 1&3 lower shroud coil mounts to, and back shroud opposite flywheel, mine are quite rusted.
Thanks in advance
Old 08-29-2018, 11:43:19 AM
RollinK RollinK is offline
Default Re: Wisconsin VH4D,charging prob.
Just went through the same exercise on my VH4D. Had the old 3 wire stator and separate rectifier/regulator setup, everything was junk. Updated to P/N YB84 two wire stator and Kohler regulator. $14 for the regulator (either Amazon or Ebay) and $105 shipped for the stator from BW welding parts in Phoenix. Much simpler setup and works very well.
Old 08-29-2018, 08:51:19 PM
s100 s100 is offline
email sent re: shrouds
Strange Points Related Problem With a VH4D tima Wisconsin Engines 15 08-26-2018 08:41:15 AM
VH4D Wisconsin Help!! Firedog413 Wisconsin Engines 5 10-08-2015 05:56:29 PM
Wisconsin VH4D overheating problem mchunt Wisconsin Engines 6 06-16-2010 11:36:16 AM
Rebuilt VH4D backfire problem. tools Wisconsin Engines 11 06-14-2010 12:44:07 AM
VH4D Wisconsin Richard F Wisconsin Engines 3 05-12-2008 12:51:19 PM
