Wisconsin Engines
Wisconsin Engine AH
this thread has 23 replies and has been viewed 1677 times
Old 08-23-2018, 06:31:20 PM
Jim Gorter Jim Gorter is offline
Default Re: Wisconsin Engine AH
After doing some grease and dirt removal I found a serial number stamped in the block just below the air vane cage. It shows AH43301. Looked up on the Wisconsin site and shows it as made in January 1938, so this engine turned 80 this year. It is in great shape for its age. Jim.
Old 08-26-2018, 05:02:26 PM
Removed carb and disassembled. After a good soak in carb cleaner, found tag with Stromberg L45A2 and inside that425041. Looking for a rebuild kit with needle valve and gaskets. Who carries the rebuild kits
Thanks, Jim.
Old 08-26-2018, 06:48:52 PM
Dodd Dodd is offline
Check with MacDonald Carb (one of our sponsors). I got gaskets for my Stromberg carbs from them. They may not have everything listed on their website, so contact them if you don't see what you need.
Aaron
The Following User Says Thank You to Dodd For This Post:
  #24
Old 09-07-2018, 02:54:53 PM
Update, Not much progress on the AH other than cleanup of some parts. Have carb kit and gasket set coming.
My next search is for a throttle spring. I have checked the local hardware stores in their spring selections, but cannot find any that have a light enough action that the air vane can compensate. I think the length can be quite variable as I will fit the throttle control to match the spring. Some suggestions on alternate spring sources is appreciated. Jim.
Wisconsin T-Head Engine Engine Expert In California?? Sean Keys Antique Gas Engine Discussion 0 02-27-2018 10:20:00 PM
Which Wisconsin Engine do I have? Angus II Wisconsin Engines 16 09-19-2017 01:46:25 AM
Can someone I.D this wisconsin engine? redding Wisconsin Engines 6 07-24-2014 09:12:20 AM
Wisconsin engine Ihorse Wisconsin Engines 2 06-25-2014 12:24:05 PM
Old Wisconsin Engine Needs Help Cowboy1on1 Wisconsin Engines 8 01-03-2014 12:41:16 AM
