Oil City Boiler Works Runs Again! Video!
this thread has 5 replies and has been viewed 1130 times
Old 08-27-2018, 11:27:32 PM
Jeff Holbrook Jeff Holbrook is offline
Talking Oil City Boiler Works Runs Again! Video!
Hello All! I hadn't run my Oil City Boiler Works Oil Field Engine in about 18 years. Brought it over from Eau Claire and got the old girl fired up at the Edgar Steam and Gas Show last weekend. Check out my video and see what you think!?!? Thanks for looking!! Jeff https://www.youtube.com/watch?v=gX-QrxQceNE
The Following 10 Users Say Thank You to Jeff Holbrook For This Post:
Old 09-04-2018, 10:12:40 PM
con-rad con-rad is offline
Default Re: Oil City Boiler Works Runs Again! Video!!
Looks good! Is it not bolted down to the skid though?
Old 09-07-2018, 02:26:13 PM
Looks and sounds good !! Thanks for sharing.
The Following User Says Thank You to Peter Holmander For This Post:
Old 09-07-2018, 11:37:40 PM
Yes, it's bolted down, but the bottom timbers are getting rotten. Plan on restoring it and replacing the timbers.
Old 09-08-2018, 10:29:50 AM
Russell Walker Russell Walker is offline
Jeff are you pumping the water? Or is it natural convection with the barrel a little higher than the cylinder. thank you Russ
The Following User Says Thank You to Russell Walker For This Post:
Old 09-13-2018, 04:52:55 PM
Natural Convection. Take about a half hour, at this speed, before it starts the water running.
The Following User Says Thank You to Jeff Holbrook For This Post:
20 HP Oil City Boiler Works Rod Bearing 65vette396 Oil Field Engines & Related Equipment 4 06-13-2016 06:31:22 AM
Oil City Boiler Works ID? Jim Stigerwalt Antique Gas Engine Discussion 0 10-03-2010 12:13:43 PM
Oil City Boiler Works ID? Jim Stigerwalt Oil Field Engines & Related Equipment 2 08-30-2009 07:45:54 PM
Oil City Boiler Works Joe Fidd Oil Field Engines & Related Equipment 6 06-17-2007 10:48:11 PM
oil city boiler works bimjy Antique Engine Archives 0 12-02-2004 11:06:53 PM
