Wisconsin Engines Single cylinder up to V4 engines. |
Key Way Groove Alignmentthis thread has 4 replies and has been viewed 512 times
Should the key way groove in shaft be lined up with the timing groove on flywheel?
Sponsored Links |
How are you going to get the key in if they don't align?
The Following User Says Thank You to Ozlander For This Post:
Don't count on it.
Install the flywheel on the crankshaft, insert a probe into #1 spark plug hole, carefully rotate the crank until the piston is at top dead center, and mark the flywheel. |
Back when I used to hotrod SBC engines , a degree wheel was a very important tool in timing the engine. it was amazing how far off some of the timing chain gears were.
If you are asking if the key way on the output side should line up, the answer is usually, if there is no clutch or gear reduction.
Bookmarks |
Thread Tools | |
Display Modes | |
Victaulic groove lock fittings. | sftyvlv1 | Steam Stationary Engines, Traction Engines, Steam Boats | 3 | 11-01-2015 11:57:24 AM |
Lister(oid) CS ring groove clearance | krawlr | Vintage Diesel and Oil Engines | 2 | 10-30-2012 12:01:25 AM |
Singh groove | John in Maryland | Antique Gas Engine Discussion | 1 | 06-11-2009 10:16:39 PM |
Removing the pins in a piston groove? | Gene Fisher | Antique Gas Engine Discussion | 7 | 04-19-2006 11:16:49 PM |
