Wisconsin Engines
Wisconsin: is this shroud correct?
this thread has 5 replies and has been viewed 548 times
Old 11-25-2018, 09:00:55 PM
Eric McKenna Eric McKenna is offline
Default Wisconsin: is this shroud correct?
I don't know much about these, shroud seams difrent than others is it correct or maybe homade
ID:	323497   Click image for larger version
Old 11-25-2018, 09:41:25 PM
Junkologist's Avatar
Images: 160
Default Re: is this shroud correct ???
That shroud is the correct early version. What is the serial number of that engine?
SmokStak member #146
Old 11-26-2018, 07:52:11 PM
Zira Zira is offline
Could we see a close up of the tag? It is usually AD/AE or AF/AG/AH engines with that style shroud, that looks smaller.
The Following User Says Thank You to Zira For This Post:
Old 11-26-2018, 09:59:38 PM
Default Re: is this shroud correct?
yes could we get a close up of the tag. I picked one up a while back but no tag
The Following User Says Thank You to slip knot For This Post:
Old 11-27-2018, 08:36:19 PM
Default Re: Wisconsin: is this shroud correct?
very hard to read ….needed magneifying glass to see.these numbers on tag
30422
AB-5092
2 1/2 x 2 3/4
1750
2
ID:	323596   Click image for larger version
ID:	323597   Click image for larger version
The Following 3 Users Say Thank You to Eric McKenna For This Post:
Old 11-29-2018, 08:39:18 PM
Wow 1937, that is an oldie.
Looking for a Decent Shroud for an AHH Wisconsin basil w. duke Wisconsin Engines 28 02-09-2018 02:40:51 PM
Wisconsin BKN Flywheel and Shroud mounting? bbarker1982 Wisconsin Engines 0 12-15-2012 06:49:16 PM
Wisconsin AKN shroud and air cleaner needed SurgeonGeneral Wisconsin Engines 0 12-28-2011 10:41:41 PM
New Way Shroud Eric McKenna Antique Gas Engine Discussion 2 03-21-2011 02:39:22 AM
New Way Shroud? Help! David M. Lyon Antique Gas Engine Discussion 5 04-14-2006 10:38:32 PM
