Wisconsin Engines
Wisconsin AENLD engine on HALE pump
this thread has 4 replies and has been viewed 301 times
Old 01-15-2019, 08:33:30 PM
Mark S in PA Mark S in PA is offline
Default Wisconsin AENLD engine on HALE pump
I have this AENLD engine on a HALE pump. The pump manual has a date of 1965 and the engine serial number shows Jan 1967. This seems to be about the correct dates. Was used at the farm for irrigation from the farm pond. Has not been used to pump water for about 35 years. Will try to attach some pictures. Is this a collectable engine? Thanks in advance for any help.
ID:	326402   Click image for larger version
ID:	326403   Click image for larger version
The Following User Says Thank You to Mark S in PA For This Post:
Old 01-16-2019, 12:11:32 AM
Default Re: Wisconsin AENLD engine on HALE pump
hey man its a old Wisconsin,likes in nice shape i'd get it runnin...very cool. don't forget to prim the pump
Old 01-16-2019, 10:23:36 AM
Heins Heins is offline
I would like to see a picture of the pump.
Old 01-16-2019, 12:07:47 PM
one more picture
Old 01-17-2019, 03:36:57 PM
KidDynamo KidDynamo is offline
It is a common engine and a good engine but you may find the crankshaft is also the pump shaft, making it less easy to use the engine for other things.
This is the scenario on a "Marlow" centrifugal pump I have that uses the same engine.
Hale made some pretty darn good fire pumps and they can still work great and can be some fun to blast water around.
And put out a fire if you find hoses and a water supply.
I learned on this site to make sure the engine's oil pump check balls are not stuck, preventing the oil pump from working. They were stuck on my oil pump despite having "rinsed" and agitated the crankcase with a load paint thinner. I had removed the base and cleaned everything spotless but didn't test the pump.
It was simple to remove the base a second time, clean and charge the pump, reassemble, and fill the sump with lube oil.
Then I had some fun pumping lots of water around but I can be easily amused with machinery.
I bought a standard crankshaft on eBay for a small amount, just in case I wanted to convert over from a pump.
Briggs and Stratton 9hp on small Hale pump Aaron W Small Air Cooled Gasoline Engines 6 01-06-2019 12:02:07 AM
Briggs Hale Fire Pump Matt166 Small Air Cooled Gasoline Engines 6 09-11-2015 11:21:48 PM
Military Wisconsin AENLD, Carver pump trowel Wisconsin Engines 4 03-11-2014 03:25:24 AM
Wisconsin AENLD Engine Won't Start ktrent Wisconsin Engines 67 01-01-2013 04:26:29 PM
Briggs & Stattton ZZP with Hale Pump deere1998 Small Air Cooled Gasoline Engines 13 07-18-2012 03:48:13 PM
