Unknown Model Engine - Oil Recomendation
this thread has 3 replies and has been viewed 370 times
Old 01-16-2019, 08:59:40 PM
Steve Taylor Steve Taylor is offline
Default Unknown Model Engine - Oil Recomendation
I've been working on this little model and was wondering if I should run SAE 30 in it or something lighter. Interesting small scale engine with adjustable timing and water pump for cooling.
Name:	OHV Model Engine (6).jpg
Old 01-17-2019, 12:35:25 AM
Default Re: Unknown Model Engine - Oil Recomendation
straight 30 wt should be fine, if your gonna run it in colder weather i'd run dead 20 wt oil, remember nondetergent oil mineral oil....
Old 01-17-2019, 03:52:06 PM
I have found that SAE 30 may be a bit too thick for models. You might try 10-30 in the crankcase. It will splash at lower speeds and lubricate just as well. Be sure to keep the rockers and pushrods lubricated, as they will wear rapidly if run dry. Interesting engine, do you know who made it?
Andrew
Old 01-17-2019, 07:25:44 PM
Andrew;
No clue as to the maker of the engine, I purchased it at an auction in Ohio. The auction had a large number of toy steam engines and a couple of unmachined Stuart steam engines so it's unclear if the prior owner did the machining or purchased it. Thanks for the information.
Unknown steam engine model oldironlindy Scale Model Engineering 4 01-06-2017 11:25:14 PM
Wisconsin VG4D oil recomendation Racsan Small Air Cooled Gasoline Engines 3 07-29-2014 11:13:23 AM
Coil and spark plug recomendation jamie10017 Onan Generators 0 11-03-2013 08:04:38 PM
RDJC Coolant Recomendation? KD5BYB Onan Generators 6 05-09-2011 12:37:32 PM
Compression recomendation Sky Small Air Cooled Gasoline Engines 3 05-25-2006 12:16:30 PM
