Oil Field Engines
Bessemer, OC/SP, and Reid oilfield engines found this week
this thread has 24 replies and has been viewed 4684 times
Old 01-30-2012, 09:22:56 PM
Jeff and Maria Smith's Avatar
Jeff and Maria Smith Jeff and Maria Smith is offline
Photo Bessemer, OC/SP, and Reid oilfield engines found this week
Hey everyone,
Thought I'd share some pics of three more old engines I've found this week.
The first is an old Bessemer that appears to have had a hard life. The engine house has fallen in on it and most of the parts have been taken. Take a look at how someone had rigged a pulley on the flywheel, using an old truck rim.
There was also an old power unit that had been use on the well at one time, along with a whole pile of wooden sucker rods.
ID:	127389   Click image for larger version
ID:	127390   Click image for larger version
ID:	127391   Click image for larger version
Old 01-30-2012, 09:28:04 PM
Default Re: Bessemer, OC/SP, and Reid oilfield engines found this week
This is the KRW power unit that was on the well site. I may be wrong, but I think it had a Ford engine on it.
ID:	127393   Click image for larger version
ID:	127394   Click image for larger version
ID:	127395   Click image for larger version
The Following 9 Users Say Thank You to Jeff and Maria Smith For This Post:
Old 01-30-2012, 09:32:45 PM
These are the wooden sucker rods on the Bessemer well location. These aren't real easy to find any more.
ID:	127397   Click image for larger version
The Following 7 Users Say Thank You to Jeff and Maria Smith For This Post:
Old 01-30-2012, 10:32:05 PM
This is the Oil City / South Penn half breed. This engine is about 100 yards beyond my property line. The engine house has fallen in on it also. The engine has one narrower square hub flywheel that I assume is the steam engine flywheel, and a wider, heavier flywheel that was probably installed with the gas cylinder. Most of the parts have been stolen off this engine also. The gas cylinder serial number is 1981. Is there a way to date these serial numbers? I know this engine is pretty old. The entire engine house is built with square cut nails, and may have been built while it was still a steam engine.
ID:	127406   Click image for larger version
ID:	127407   Click image for larger version
ID:	127408   Click image for larger version
The Following 12 Users Say Thank You to Jeff and Maria Smith For This Post:
Old 01-30-2012, 10:47:43 PM
These are photos of what is left of the OC/SP engine house, wooden cooling tank, and the square cut nails that the engine house is built with.
ID:	127410   Click image for larger version
ID:	127411   Click image for larger version
The Following 13 Users Say Thank You to Jeff and Maria Smith For This Post:
Old 01-30-2012, 10:57:47 PM
Rod Fielder Rod Fielder is offline
go get em jeff
Old 01-30-2012, 11:42:40 PM
The Reid is about 50 to 75 yards beyond the OC/SP. Both of them are well within a quarter mile of my house.
As you can see, the Reid engine house is perched on the side of the hill, just like the OC/SP was. Not too many ways to build a good flat location back then, other than by hand. This one is sort of unusual as it has been built up with a stone foundation.
Most of the small parts have been taken, as usual. The serial number is odd as it has been stamped over and one number different from the crank serial number. The number stamped on the bed plate and the cylinder are both 7985. It appears that the number was originally 7925, but in both, the 2 was changed to an 8. The number on the crank is one number lower, 7984. Wonder what the deal is with that? Can someone date the engine by the serial number for me?
ID:	127428   Click image for larger version
ID:	127429   Click image for larger version
ID:	127430   Click image for larger version
The Following 14 Users Say Thank You to Jeff and Maria Smith For This Post:
Old 01-30-2012, 11:46:03 PM
These are pics of the serial numbers on the cylinder, base, and crank.
ID:	127432   Click image for larger version
The Following 3 Users Say Thank You to Jeff and Maria Smith For This Post:
Old 01-30-2012, 11:54:16 PM
I'd like to Rod. The only one that I may be able to get is the Bessemer. I haven't heard back from the owner yet. The other two are owned by an oil and gas company that will not sell any of them. You see the condition they are in, but they will not sell!
I can find them by the dozens, just can't get any of them. Within a 5 mile area of my house, I can take you to probably 50+ engines. problems is the two oil companies that own 90% of them, will not sell. So, I photograph and document them, I guess just for history's sake.
The Following 15 Users Say Thank You to Jeff and Maria Smith For This Post:
Old 01-31-2012, 12:18:58 AM
Great finds Jeff. The Reid is a 1913 regardless of which serial number is correct.
The Following User Says Thank You to Ray Ethridge For This Post:
Convertable Oilfield Engines Doug Waggonner Oil Field Engines & Related Equipment 7 12-20-2010 09:09:33 PM
Another Bessemer found hiding in the woods Jeff and Maria Smith Oil Field Engines & Related Equipment 8 11-09-2010 07:18:08 PM
Look What I Found In Japan Last Week Doug Hanneman Antique Gas Engine Discussion 12 08-22-2010 08:34:35 PM
Bessemer Oilfield engines at Rushville In 2006 Fred Van Hook Oil Field Engines & Related Equipment 4 08-01-2007 05:02:18 PM
Oilfield Powers and Engines Tim Knierim Antique Engine Archives 0 09-12-1999 10:48:57 AM
