Wisconsin Engines
Wisconsin Parts Never Been Used for Sale
this thread has 63 replies and has been viewed 27118 times
Old 05-06-2012, 02:27:14 PM
JerseyMowers JerseyMowers is offline
Default Wisconsin Parts Never Been Used for Sale
My father owns a small engine repair shop that was originally started by my great-grandfather. They were once a Wisconsin/Wisconsin-robin dealer and over the years stocked many of parts which are still on the shelf. I have consolidated many of the parts and have no use for them and was wondering if their is anyone still interested in rebuilding the old Wisconsin motors. The parts consist of a range of pistons, rings, connecting rods, cylinder heads, head gaskets and gasket sets, carb repair kits, carb air horns fuel tank brackets, engine shrouds, fuel pumps, valves, valve springs, valve spring retainers, shell bearings, a few ignition components, engine instruction manuals, and miscellaneous parts and more. Most of the parts fit models AGN, AENL, AEND, VG4D, VH4D, TJD, THD to the best of my knowledge. If anyone is interested i can send a file with part numbers and descriptions and can also take pictures if needed. We also have a collection of Wisconsin-Robin parts I have not sorted yet if anyone is interested, thanks for looking.
Old 05-07-2012, 03:40:44 PM
Andries Andries is offline
Default Re: Wisconsin parts never been used for sale
Hello JerseyMowers,
I'm looking for parts and information of a Wisconsin AF type engine with a Stromberg UR 3/4" carb.
Are there any parts or information for an AF engine or Stromberg UR 3/4" carb.
Looking for fuel tank round 1-1/2gal. PartNo: WE-14-A.
Andries
Old 05-07-2012, 04:23:34 PM
Road Torpedo Road Torpedo is offline
It's probably best to put a big add in the classifieds.
The classic original WISCONSIN parts will usually sell without problems.
Wisconsin ROBIN parts on the other hand...not so much.
Not to many are fans of the robins. Including me.
The Following User Says Thank You to Road Torpedo For This Post:
Old 05-07-2012, 06:44:19 PM
Thanks for the information. I'm new to this forum, is their a specific area for Wisconsin classified ads or should I use the link above that says "Classified Ads" between the chat and subscribe links?
Old 05-07-2012, 10:56:30 PM
bbarker1982 bbarker1982 is offline
AENL engine shroud available?
Old 05-08-2012, 11:29:27 PM
Just go to the classified ads and list under small engine's. That'll do'er.
Old 05-10-2012, 08:11:01 AM
poopysdaddy poopysdaddy is offline
do you have a hub/flywheel to fit V465D 10 inch clutch ?
thanks
my email: generalsewerservice@msn.com
Old 05-11-2012, 12:54:39 PM
David Boothby David Boothby is offline
yes i would be enterested in the single cylinder engine wisconsin parts can you send lists and pictures efanks dave
Old 05-11-2012, 09:27:36 PM
oldschoolwisconsin oldschoolwisconsin is offline
I need a few parts for my AHH wisconsin. I need a gasket set for the engine, and I need a gasket set for its Stromberg carburetor as well.
Old 05-12-2012, 06:04:43 PM
I forgot to mention I need the fuel bowl gasket too.
Old 05-13-2012, 03:59:41 PM
Don Shilling Don Shilling is offline
Jersey, Please contact me at starman@vintageacres.co
I have two VH4D's that I need parts for.
Thanks,
Don Shilling
Old 05-20-2012, 07:57:23 PM
Damato Damato is offline
Looking for parts to completly overhaul a Wisconsin VH4D. According to the serial number, it was made in 1943.
Old 05-23-2012, 06:53:34 PM
jordanta jordanta is offline
I have a robin generator model 505d .. Just checking to see if you have parts for it. Thanks tom
a list of parts would be great.
Old 05-26-2012, 05:09:05 PM
I attahced a word document with the list of part numbers i have checked in so far. If anyone is interested for the whole package that would be great.
Old 01-02-2013, 09:17:44 PM
Koiti Koiti is offline
Looking for parts for Tfd and Thd Wisconsin eng. Head gasket,Pan gasket and adding crank handle to start.May need a carburator gasket for Zenith Carb.
Old 01-10-2013, 03:40:57 PM
Ralph Simpson Ralph Simpson is offline
I need an air cleaner and intake elbow for an AEH, AENL, AKN and BKN.
Also need a carb for a BKN. If you do not have any to sell, I would appreciate a photo of them so I can identify them if I come across any. Thanks
---------- Post added at 02:40 PM ---------- Previous post was at 02:35 PM ----------
My email is: backacheacres@windstream.net
Old 01-10-2013, 03:44:47 PM
Brian W Brian W is offline
could you send me a list of available parts? I am looking for a piston, rings, gaskets, and an engine base for a wisconsin AGND
my email is: brianwilliams611@yahoo.com
thanks, Brian
Old 01-30-2013, 06:27:06 PM
Do you have a carburater mounting tube for an AEH?
Old 03-02-2013, 11:45:49 AM
Rikkoski Rikkoski is offline
Need can shaft, gasket set and few other parts for Wisconsin s7d. By any chance you might have them. Contact phone 906 396 1033
Old 03-03-2013, 05:27:26 AM
tpost76 tpost76 is offline
Looking for a camshaft gear assembly part #EA115BS1 for Wisconsin AGND. Any leads ? Thanks
For Sale Engines and Parts Crossley Kid Smokstak Down Under 0 10-06-2015 08:43:38 PM
wisconsin EY27W for sale Huey1969 Wisconsin Engines 0 12-22-2011 09:02:23 PM
For Sale 4 old Tractors for Parts jrh Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 04-26-2010 03:25:18 PM
Case parts that may be for sale Grape Steam Stationary Engines, Traction Engines, Steam Boats 12 06-24-2009 12:17:00 AM
