Vintage Diesel and Oil Engines Fairbanks Morse, Lister, Petter, Witte and other pump injected Diesel oil engines. |
Fairbanks Morse 36 A diesel 10 hpthis thread has 13 replies and has been viewed 4247 times
I recently got a FM diesel model 36 A 10 hp.
I am in need of info on bleeding air from the fuel system. Is there a manual or other info available for this engine. Any info is welcome.Thank You. |
Sponsored Links |
The return line from the lift pump needs to return to the tank, teeing it in the supply line does not work. The screw on top of the injection pump is the blead screw (between the two lines). loosen it and pump the manual lever till no air bubbels come out. tighten it and loosen the injector line at the injector. with the compression release on crank the eng. over till fuel comes out there. tighten the line and crank some more ,you should hear the injector start making a squeaking noise each time it delivers fuel. Make sure the rack is free, pull towards you to stop eng. Mine is hand crank start, with release on crank as fast as you can and flip it off. should start, when cold heat in the air intake helps.
The Following 2 Users Say Thank You to Tom Marshall Jr. For This Post:
I have pictures of my FM 36A that I will post in two replies.
The fuel pump looks new and I am thinking it is not original ? It shows no diesel residue .Would the bale thing be to manually acuate the pump? Although the engine was in a barn for 20+ years, the unpainted injector and pump have surface rust on them.I cleaned and lubed the injection pp.rack but it does not move?I'm thinking it may not move without governor action.I ddn't want to break something. Anyone know of a source for a owners or parts manual.I could not seem to find any with a Google search. I appreciate any information or ideas you may have. PS : Please excuse the paint color,I DIDN'T DO IT ! |
The Following 3 Users Say Thank You to Jim McCracken For This Post:
The rest of the pictures:
I recently bought same 36A single, I'm looking for complete Cylinder head (top end) maybe sleeve too. - note: any 36A with 1,2,34,6 and 8 cylinders are interchangeable.
The Following 2 Users Say Thank You to Redwing For This Post:
DONT START IT UNTILL THE RACK CAN MOVE |
The Following User Says Thank You to Darryl For This Post:
Jim, try unhooking the gov. linkage. If it still doesn't move, the pump may be dry. A disassemble may be in order, but first try some WD.
Have you turned the engine over yet? There's a little timing window on the base of the pump, you should be able to see the plunger cup moving up and down. Gently turn the engine with the compression release open. If you feel any objectional resistance the pump may be stuck. If it turns over easily and the plunger doesn't move, it is likely stuck in the up position. In either of those circumstances, and if it were mine, I would be tearing the pump down to see what's up. If the plunger is moving try moving the rack while the plunger is moving. Some times that will help loosening the rack. If it comes down to a tear down, I can scan and send you some pages from an Am Bosch manual. They are not really complicated but there are some things that you will need to follow carefully. Otherwise your pump could end up on the scrap pile. Good luck. GUS This is my 3 cylinder genset shortly after I got it. I wish the factory base came with it. ![]() |
The Following 6 Users Say Thank You to GeneratorGus For This Post:
Most likely situation as others have said is that your injector is stuck. If you google around you can find CAV/Bosch/Ambac manuals online for these units like here at a members (Lister Diesel) website:
http://www.oldengine.org/members/diesel/front.htm I can high quality copy and nicely bind a Shop/Parts manual for a little money to cover costs if you wish, PM me your address. Cheers Nobby Oops this is an old initial post, oh well. For anyone that needs one offer on manual copies still stands. Cheers Nobby |
The Following User Says Thank You to Nobby For This Post:
Anyone know who has extra complete head or parts around for my 36A ? I like to restore someday.
There's a chance that I might have access to some. I'll let you know if it pans out.
Cheers Nobby |
Bookmarks |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | F o r u m | Replies | Last Post |
Fairbanks Morse Y Diesel | John Cunningham | Vintage Diesel and Oil Engines | 19 | 02-11-2016 04:47:06 PM |
300 HP Fairbanks Morse Diesel Needs a Home! | David Babcock | Antique Gas Engine Discussion | 10 | 04-26-2012 11:45:42 PM |
Fairbanks Morse 20hp diesel help | Dave V. | Vintage Diesel and Oil Engines | 5 | 05-07-2006 02:44:17 PM |
Fairbanks MORSE YH Diesel | Carl | Antique Engine Archives | 0 | 07-29-2001 03:06:30 PM |
Fairbanks Morse Y Diesel | Carl | Antique Engine Archives | 10 | 06-21-2001 12:47:08 AM |
