Fairbanks Morse 36 A diesel 10 hp
this thread has 13 replies and has been viewed 4422 times
Old 09-09-2012, 12:27:49 PM
Jim McCracken Jim McCracken is offline
Default Fairbanks Morse 36 A diesel 10 hp
I recently got a FM diesel model 36 A 10 hp.
I am in need of info on bleeding air from the fuel system.
Is there a manual or other info available for this engine.
Any info is welcome.Thank You.
Old 09-09-2012, 07:53:47 PM
Tom Marshall Jr.'s Avatar
Tom Marshall Jr. Tom Marshall Jr. is offline
Images: 1
Default Re: Fairbanks Morse 36 A diesel 10 hp
The return line from the lift pump needs to return to the tank, teeing it in the supply line does not work. The screw on top of the injection pump is the blead screw (between the two lines). loosen it and pump the manual lever till no air bubbels come out. tighten it and loosen the injector line at the injector. with the compression release on crank the eng. over till fuel comes out there. tighten the line and crank some more ,you should hear the injector start making a squeaking noise each time it delivers fuel. Make sure the rack is free, pull towards you to stop eng. Mine is hand crank start, with release on crank as fast as you can and flip it off. should start, when cold heat in the air intake helps.Click image for larger version
The Following 2 Users Say Thank You to Tom Marshall Jr. For This Post:
Old 09-12-2012, 05:10:31 PM
I have pictures of my FM 36A that I will post in two replies.
The fuel pump looks new and I am thinking it is not original ?
It shows no diesel residue .Would the bale thing be to manually acuate the pump?
Although the engine was in a barn for 20+ years, the unpainted injector and pump have surface rust on them.I cleaned and lubed the injection pp.rack but it does not move?I'm thinking it may not move without governor action.I ddn't want to break something.
Anyone know of a source for a owners or parts manual.I could not seem to find any with a Google search.
I appreciate any information or ideas you may have.
PS : Please excuse the paint color,I DIDN'T DO IT !
ID:	144702   Click image for larger version
ID:	144703   Click image for larger version
ID:	144705   Click image for larger version
The Following 3 Users Say Thank You to Jim McCracken For This Post:
Old 09-12-2012, 05:15:05 PM
The rest of the pictures:
ID:	144707   Click image for larger version
ID:	144708   Click image for larger version
ID:	144709   Click image for larger version
Old 04-09-2014, 11:22:37 PM
Redwing Redwing is offline
I recently bought same 36A single, I'm looking for complete Cylinder head (top end) maybe sleeve too. - note: any 36A with 1,2,34,6 and 8 cylinders are interchangeable.
ID:	192719   Click image for larger version
ID:	192720   Click image for larger version
ID:	192721   Click image for larger version
The Following 2 Users Say Thank You to Redwing For This Post:
Old 04-10-2014, 02:24:26 AM
Darryl Darryl is offline
DONT START IT UNTILL THE RACK CAN MOVE
The Following User Says Thank You to Darryl For This Post:
Old 04-10-2014, 07:20:56 AM
GeneratorGus's Avatar
GeneratorGus GeneratorGus is offline
Jim, try unhooking the gov. linkage. If it still doesn't move, the pump may be dry. A disassemble may be in order, but first try some WD.
Have you turned the engine over yet? There's a little timing window on the base of the pump, you should be able to see the plunger cup moving up and down. Gently turn the engine with the compression release open. If you feel any objectional resistance the pump may be stuck. If it turns over easily and the plunger doesn't move, it is likely stuck in the up position.
In either of those circumstances, and if it were mine, I would be tearing the pump down to see what's up.
If the plunger is moving try moving the rack while the plunger is moving.
Some times that will help loosening the rack.
If it comes down to a tear down, I can scan and send you some pages from an Am Bosch manual. They are not really complicated but there are some things that you will need to follow carefully. Otherwise your pump could end up on the scrap pile.
Good luck.
GUS
This is my 3 cylinder genset shortly after I got it.
I wish the factory base came with it.
The Following 6 Users Say Thank You to GeneratorGus For This Post:
Old 04-10-2014, 09:36:25 AM
Nobby Nobby is offline
Most likely situation as others have said is that your injector is stuck. If you google around you can find CAV/Bosch/Ambac manuals online for these units like here at a members (Lister Diesel) website:
http://www.oldengine.org/members/diesel/front.htm
I can high quality copy and nicely bind a Shop/Parts manual for a little money to cover costs if you wish, PM me your address.
Cheers
Nobby
Oops this is an old initial post, oh well. For anyone that needs one offer on manual copies still stands.
Cheers
Nobby
The Following User Says Thank You to Nobby For This Post:
Old 04-10-2014, 09:56:13 PM
Anyone know who has extra complete head or parts around for my 36A ? I like to restore someday.
Old 04-10-2014, 10:02:45 PM
There's a chance that I might have access to some. I'll let you know if it pans out.
Cheers
Nobby
Old 11-20-2018, 10:36:45 PM
Scott Hosack Scott Hosack is offline
I know this is an old thread but I was just wondering if Redwing ever found a head or was able to save the 36A generator set? I recently bought a restored 10hp 36A with no attachments and have found any information nearly impossible to come up with on this engine. I am fairly certain mine was originally a compressor set up but all the extras are long gone now. How long did they make the 36A and what all were they used for?
Old 11-21-2018, 08:33:45 PM
enginenut2 enginenut2 is offline
Scott, My volume 10 (1945) "Diesel Engine Catalog" lists the model 36 in 1,2,3,4,& 6 cyl of 4 1/2 X 6 bore and stroke having 10 HP/cyl and a larger model 36 of 5 1/2 7 1/2 in 6 & 8 cyl giving 20 HP/cyl. My next dated catalog of 1954 doesn't list the model 36 but lists engines of similar output made by Harnischfeger and Sheppard.
Model 36 described as medium speed, intended for hard continuous work in the stationary,industrial and marine fields. Industrial they list: locomotive cranes, power shovels, air compressors, small locomotives and similar. The larger engines were said to be designed to allow conversion to gaseous fuel. A very robust design with the crankshaft and bearings carried in the base NOT the cylinder block. Bearings and internals were accessed through the covers on the side.
The Following User Says Thank You to enginenut2 For This Post:
Old 11-24-2018, 06:43:49 AM
Scott, not sure how long they made them, but they had many uses.
ID:	323424   Click image for larger version
ID:	323425   Click image for larger version
ID:	323426   Click image for larger version
The Following 5 Users Say Thank You to GeneratorGus For This Post:
Old 12-02-2018, 06:38:26 PM
My engine was originally an air starting compressor but all I have is the engine unfortunately. It is a 1943 by the serial number stamped in the base. The flywheel is very wide at almost 6 1/2" wide. Most I have seen were maybe up to 4" wide. The picture of the tag stamped in the radiator shroud reads Diesel Starting Air Compressor #1. Would anyone know if it might have possibly been in a ship or maybe used in a electric generating plant for the air start tanks?
ID:	323874   Click image for larger version
ID:	323875   Click image for larger version
Fairbanks Morse Y Diesel John Cunningham Vintage Diesel and Oil Engines 19 02-11-2016 04:47:06 PM
300 HP Fairbanks Morse Diesel Needs a Home! David Babcock Antique Gas Engine Discussion 10 04-26-2012 11:45:42 PM
Fairbanks Morse 20hp diesel help Dave V. Vintage Diesel and Oil Engines 5 05-07-2006 02:44:17 PM
Fairbanks MORSE YH Diesel Carl Antique Engine Archives 0 07-29-2001 03:06:30 PM
Fairbanks Morse Y Diesel Carl Antique Engine Archives 10 06-21-2001 12:47:08 AM
