Oil Field Engines
Bessemer Oil Field Engine Found in Original Engine House Needs Rescue
this thread has 25 replies and has been viewed 6743 times
Old 07-03-2013, 07:11:57 AM
West Virginia Well West Virginia Well is offline
Default Bessemer Oil Field Engine Found in Original Engine House Needs Rescue
I have a Bessemer oil field engine that is currently located in the original engine house and has been untouched for more than fifty years. I would like to relocate the derrick, fulcrum, engine house and engine to a new location and resurrect the entire site and make it fully operational. I am looking for OFES members that would like to get involved in the project. The site is located near Morgantown and the new site will be on the same property. The purpose of the move is to restore the rig and preserve it for future generations. I would like to make the rig available to OFES members to enjoy after the move is complete.
ID:	168755   Click image for larger version
Name:	engine house.jpg
ID:	168756   Click image for larger version
Name:	ole besse.jpg
ID:	168757   Click image for larger version
Old 07-03-2013, 08:28:41 AM
Mike G Mike G is offline
Default Re: Bessemer Oil Field Engine Found in Original Engine House Needs Rescue
Welcome to the Stak!
It was nice talking to you last night, I know you will find all of the help you need here!
Mike
The Following User Says Thank You to Mike G For This Post:
Old 07-03-2013, 03:35:04 PM
Mike,
The pleasure is mine. Thank you.
Regards,
Neal
Old 07-03-2013, 03:39:43 PM
Bob Willman Bob Willman is offline
The Wood County Historical Society in Bowling Green, Ohio has a steam powered drilling rig with steel derrick very similar to this one. I believe the derrick came from West Virginia. The steam engine and boiler came from Lima, Ohio where they had a wooden derrick that was not salvageable. We run it under steam during our Heritage Days show.
www.woodcountyhistory.org
Bob
WB8NQW
The Following User Says Thank You to Bob Willman For This Post:
Old 07-05-2013, 01:47:27 PM
Tremel Tremel is offline
Looking at the derrick, it appears to be a drilling rig. The drilling rigs are a bit rare, as they were typically moved from well to well. Most of the derricks that survived into the late 1900's and early 2000's are baling rigs. The baling rigs are typically made out of pipe. And sometimes smaller.
I helped move a drilling rig in 1986 (I was 16) to NationalPike, just north of Morgantown. We then re-moved the rig to a new location on the fairgrounds last year. (www.nationalpike.com)
I removed two other rigs and rebuilt one for another individual.
Drop me a line sometime and I'll share what I know. I"m also somewhat local to Morgantown (about an hour away). I would like to see more pics of the rig.
The Following User Says Thank You to Tremel For This Post:
Old 07-05-2013, 10:25:57 PM
Chris Austin's Avatar
Chris Austin Chris Austin is offline
Tremel,
It looks to me that the derrick in the picture is made from pipe(legs) with angle iron x bracing.
Old 07-07-2013, 12:06:04 AM
Jeff Smith Jeff Smith is online now
I find it very exciting that this well still exists in Morgantown! I thought that all of them have been removed, but at least one has made it past the scrappers!
I wonder if I went to this well as a child because I used to go with a friend that was a pumper once in a while.
I would like to see this well the next time I head home.
Jeff
Old 07-07-2013, 09:32:40 PM
Sounds good, Jeff Smith. Stay in touch and let me know the next time you're in the area.
The Following User Says Thank You to West Virginia Well For This Post:
Old 07-07-2013, 09:55:06 PM
Jonah Close Jonah Close is offline
I think that coolspring should get one of these.
The Following User Says Thank You to Jonah Close For This Post:
Old 07-08-2013, 09:07:57 AM
let's bring it to coolspring. fine with me.
Bessemer? Found large compressing engine... Jonah Close Oil Field Engines & Related Equipment 6 09-28-2012 05:19:07 PM
i found an engine dreaming about a house tailboardtech Steam Stationary Engines, Traction Engines, Steam Boats 9 09-14-2012 12:56:44 PM
Oil field engine in pump house Rod Fielder Antique Gas Engine Discussion 9 09-15-2010 04:57:51 PM
Trade school engine found in old Chicago house. TBuchanan Antique Gas Engine Discussion 9 09-04-2010 07:23:43 PM
Found two to rescue... Rex Pyles Antique Gas Engine Discussion 19 07-08-2010 07:47:10 AM
