Jacobson Machine Mfg. Co., Warren, Pennsylvania
this thread has 396 replies and has been viewed 76711 times
Old 11-25-2016, 06:10:12 PM
Denis Rouleau's Avatar
Denis Rouleau Denis Rouleau is offline
Default Re: Jacobson Machine Mfg. Co., Warren Pa.
Originally Posted by Sunnybrook View Post
I would like to share some pics of my nice original Sturdy Jack pumper #5153 and ask that you add it to your list Denis, Thanks!
Your engine has been added here:
http://buzzcoil.brinkster.net/moody/page101.html
Anyone else have a Jacobson for the registry?
Denis Rouleau
Old 11-25-2016, 07:59:23 PM
Galan Hackman Galan Hackman is offline
Dennis,
I see this engine is not on your registry.
Galan
ID:	268771   Click image for larger version
The Following 3 Users Say Thank You to Galan Hackman For This Post:
  #383
Old 11-25-2016, 09:45:21 PM
Don Worley Don Worley is offline
Original 7 hp Jacobson on an original cart. Original skid and battery box.
The serial number is written on the inside of the lid. I have seen several boxes with the number in the box.
ID:	268790   Click image for larger version
ID:	268791   Click image for larger version
ID:	268792   Click image for larger version
The Following 3 Users Say Thank You to Don Worley For This Post:
  #384
Old 11-25-2016, 10:14:58 PM
Slip from 1903. It does not mention making gas engines.
The Following User Says Thank You to Don Worley For This Post:
  #385
Old 11-28-2016, 02:20:03 PM
Heavy Metal Heavy Metal is offline
Don, Is the engine original to that cart? I thought the portables were painted green.
Old 11-28-2016, 05:15:39 PM
So did I. All the woodwork is the same color as the engine and appears to be original. The cart is identical as one from factory advertising. I have a green 7 hp Jacobson. As soon as I think that I have things figured out I am proved wrong.
The Following 2 Users Say Thank You to Don Worley For This Post:
  #387
Old 12-02-2016, 12:44:00 PM
Don, is there a story behind that picture? We don't often see a trailer full of Jacobson engines!
The Following 2 Users Say Thank You to Denis Rouleau For This Post:
  #388
Old 11-03-2017, 08:45:53 PM
Ed Allandar's Avatar
Ed Allandar Ed Allandar is offline
Images: 7
Photo Re: Jacobson Machine Mfg. Co., Warren Pa.
Brought Ward # 3579 back home to Pennsylvania - 5 HP Type GE
ID:	295189   Click image for larger version
The Following 2 Users Say Thank You to Ed Allandar For This Post:
  #389
Old 11-03-2017, 10:00:24 PM
Tim B's Avatar
Tim B Tim B is offline
Hi Don, any pictures of the 1903 air compressor?
Old 11-04-2017, 09:57:27 AM
Do you have one? Any pictures?
The Following User Says Thank You to Denis Rouleau For This Post:
  #391
Old 11-04-2017, 10:09:26 AM
Tim B's Avatar
No Denis, sorry, I don't. Ive never heard of one that is why I was inquiring about a picture. Thanks.
Old 11-09-2017, 02:10:39 PM
Randy Hart's Avatar
Randy Hart Randy Hart is offline
Images: 2
Here is a jacobson compressor. I haven't found any numbers yet on it. And a photo of a jacobson engine from a show that is the same casting as the compressor.
ID:	295682   Click image for larger version
ID:	295683   Click image for larger version
ID:	295684   Click image for larger version
He who dies with the most STUFF wins!
The Following 2 Users Say Thank You to Randy Hart For This Post:
  #393
Old 11-10-2017, 04:10:37 PM
BSerfass BSerfass is offline
Yesterday I had created a thread for a Maynard that I have just brought home. It is starting to look like it was a Jacobson. I think it started as an engine and someone converted this to a air pump. Any more info would be appreciated.
ID:	295762   Click image for larger version
ID:	295763   Click image for larger version
ID:	295764   Click image for larger version
Old 05-26-2018, 04:41:34 AM
Jonesey Jonesey is online now
Hi Denis
Iíve just finished restoring a Jacobson 2hp Sturdy Jack Pump and see itís not on the register, itís serial number is 5425, could you add it to the list with the below photos and do you know of anymore that are located in Australia ?
I do have a problem with it, when it starts up and gets to around 500rpm it gets a bad vibration, is this normal for that style of Jacobson considering itís only 1 flywheel. The flywheel runout is only .3mm but there is a smallish hole in the outside of the flywheel refer photo.
Thks Les
ID:	311226   Click image for larger version
ID:	311227   Click image for larger version
ID:	311228   Click image for larger version
The Following User Says Thank You to Jonesey For This Post:
  #395
Old 05-26-2018, 06:16:11 AM
Thanks Les for sending in pictures of your nice little Jacobson engine.
I've added it to the Jacobson registry here:
I have not had the chance to own one of these so I don't known how they usually behave.
Its been a long time since I was able to add to the Jacobson registry, so if you have one that is not in the registry, please contact me and I will gladly do so.
Denis Rouleau
  #396
Old 02-23-2019, 10:42:41 PM
Preston Wells's Avatar
Preston Wells Preston Wells is offline
Images: 37
Default Re: Jacobson Machine Mfg. Co., Warren, Pennsylvania
Dennis and Don here are some pictures of a 3 hp type GE Ward engine. With s.n. 3837 Im thinking this might be a pretty early production engine. Would like to enter this into your registry if it is not already there. Would also like to know the year of manufacture. Am looking forward to getting this engine up and running again and building a new cart for it. I have a question for Don W if a crank guard is available and if there is documentation of the correct grease cups used on the mains and rod bearing. Thanks for any information you can provide.
ID:	329275   Click image for larger version
ID:	329276   Click image for larger version
ID:	329277   Click image for larger version
"There is more to life than what we see"
www.youtube.com/user/theoldengine1
Preston
FL
The Following User Says Thank You to Preston Wells For This Post:
  #397
Old 02-24-2019, 08:59:04 AM
Hi Preston, I've added your Jacobson to the Jacobson registry here:
In my estimate your Jacobson was built around 1912.
If someone else has a Jacobson they want added to the registry, now is a good time to contact me and I will gladly add it to the Jacobson registry.
Thank you!
Denis Rouleau
Machine shop in western Pennsylvania? J. Sutter Antique Gas Engine Discussion 3 09-25-2014 09:33:33 PM
THe Little Elgin-RA warren Tom Hartfield Small Air Cooled Gasoline Engines 1 03-05-2012 05:31:18 PM
Jacobson Machine Mfg. Co. Warren, Pennsylvania (PICTURES) Denis Rouleau Antique Gas Engine Discussion 10 06-18-2011 11:15:59 PM
WD-40 IH at J.B. Warren Sale Eric Best Antique Farm Tractors 0 09-23-2005 09:35:45 PM
