Maytag After Market Coil for 72
this thread has 14 replies and has been viewed 4857 times
Old 01-04-2015, 09:08:12 PM
Teardropbldr Teardropbldr is offline
Default Maytag After Market Coil for 72
Hi folks,
I know this has been a topic that has been hashed out many a time. I just picked up a 1948 model 72 engine. Everything thing about the motor is great. Parts are in good condition, with no damage. I checked coil with a meter, and found it to be bad. I want to use a aftermarket coil to save on money. Can someone provide me a picture of one that has been replaced, along with part number. Maybe even the box it came in. There has been a lot of part numbers thrown around, but nothing visual to reference by.
Thank you for your time!!
Alan
Old 01-05-2015, 12:45:20 PM
Kevin Weis Kevin Weis is offline
Default Re: Maytag after market coil for 72
Eisemann or Wico magneto? There were the two versions. Two people make an after market coil for them. Zach Northway and Bob Blin (Bob's Small Engine). Thin their both sponsors here. I think Zach is currenly out of the Wico coils. Either way your looking at about $150 + shipping to get it to you. There are no other suppliers out there for these that I'm aware of. Others can chime in. You may be fortunate enough to come accoss a "hot" coil off of ebay but you'll pay about the same and it may go dead a few minutes after running which is typical. The Wico magneto seems to hold up better for some reason though. Hope this helps.
Kevin
The Following 2 Users Say Thank You to Kevin Weis For This Post:
Old 01-05-2015, 02:19:14 PM
Assuming that is a Eisemann , Go to Ebay and search Maytag coil. There is one original for $165. New coil $150 from Zach. An original coil can go bad at any time. I've had it happen a couple of times.I've even experimented with Briggs coils with limited success. I finally broke down and bought 2 of Zach's coils. You have to pull off the old coil and push on the new coil and hook up the wires of course. Ron
The Following User Says Thank You to Ronald E. McClellan For This Post:
Old 01-05-2015, 10:02:46 PM
WesleyGrissom's Avatar
WesleyGrissom WesleyGrissom is offline
There is a thread on here somewhere that explains how to adapt a $37 aftermarket briggs and stratton coil. Includes a part # for Napa.
The Following User Says Thank You to WesleyGrissom For This Post:
Old 01-05-2015, 10:56:31 PM
Mark Shulaw Mark Shulaw is offline
The Briggs coil conversions never work very well. They will turn the wheel but with only limited success. Zack is selling the only coil that works. Bob is not currently making any so he tells me.
Mark S
The Following 2 Users Say Thank You to Mark Shulaw For This Post:
Old 01-06-2015, 12:27:02 AM
Thank everyone for the great feedback!
---------- Post added at 11:27 PM ---------- Previous post was at 11:18 PM ----------
I heard that it is possible to have a false reading with a meter that indicated coil was bad. When that person put the motor back together, she fired up. I guess wishful thinking.
Old 01-06-2015, 06:44:50 AM
Dennis Wyatt's Avatar
Dennis Wyatt Dennis Wyatt is offline
Images: 138
Try this. It's about the best way to test the coil. https://www.youtube.com/watch?v=r8406tCOXzA
Dennis
http://www.youtube.com/user/djjr4fun#p/u
The Following 2 Users Say Thank You to Dennis Wyatt For This Post:
Old 01-07-2015, 12:20:43 AM
Teardrop, that might have been me. Recently I restored a Wico 72 whereby a multiimeter showed no continuity but fired up and ran well. Probably some corrosion or minute break in the winding and the current is jumping this without issue. We'll see how long that last. Maybe a post about that three months ago or so.
Regards, Kevin
The Following User Says Thank You to Kevin Weis For This Post:
Old 01-07-2015, 10:17:47 AM
Kevin Yes it may have a small break in the wire. It will slowly burn the wire and form a carbon trail and will still work until it causes the spark to get too weak to run the engine. Ron
Old 01-07-2015, 11:42:12 PM
Yes, that is what I am hoping on Kevin. Everyone who is ready to pitch their old coil when the meter reads 0, should watch this video.
http://youtu.be/22NdLNo74Hk
Old 01-09-2015, 07:55:11 PM
gambitace71 gambitace71 is offline
hi, google serch gravely guy.com and go to the parts and services page.there is a guy there that rewinds coils for all kinds of magnetos.he has been rewinding mine for years.thanks
Old 01-10-2015, 10:58:52 PM
www.oldcroak.com/ I didn't see the maytag coils on the site but I know he has them he has done a few for me.
Old 09-17-2018, 03:18:04 PM
Big Boose Big Boose is offline
I have a model 72 maytag on a Zip push mower. It was missing the armature, found one on ebay. There was spark during initial test, but now after several weeks waiting for other parts, I find there is no spark. Test with ohm meter shows open in coil. I get no spark when using 6 volt battery connected to stationary side of points and touching pivoting side of points with paper bbetewwn contacts. Would you tell me how to contact Zach Northway to poaaibly get an aftermarket coil?
Old 09-17-2018, 07:10:45 PM
Default Re: Maytag After Market Coil for 72
ebay item #381856571833
Old 09-17-2018, 07:46:22 PM
You need to buy it off his eBay store or at one of the shows he attends. As far as I know he is the only one making/selling these. Kevin
Maytag 92 Coil vascon2196 Maytag Engine Collectibles 18 12-28-2015 09:56:15 AM
Maytag 82 Coil MedicHamilton Maytag Engine Collectibles 5 01-07-2011 01:56:25 PM
Maytag 72d coil bert1512 Magnetos, Ignition Coils and Spark Plugs 1 09-26-2008 04:07:37 PM
Maytag 72 coil Frank Timmermeier Maytag Engine Collectibles 2 03-10-2008 09:47:51 AM
maytag coil larry harding Antique Engine Archives 6 05-20-2001 09:13:49 PM
