Maytag Engine Collectibles Maytag engines, washing machines, mowers and other engine driven tools for the farm. |
Maytag Upright 1/2hp Connecting Rodthis thread has 6 replies and has been viewed 1866 times
Hi i am after a 1/2hp maytag upright connecting rod
But i am in the uk so if you are willing in posting it me Then that it great Thanks oliver |
Sponsored Links |
Is your rod missing or just worn out? If worn, it might pay too have it bored and have bushings installed. Check your wrist pin and crank pin too - they wear and get out of round.
Hi
They doesnt look enough meat on the conrod to have a bush |
Plug it and silver brass or weld it as you would say.
Then rebore it. |
A man named Larry Simson used to bush these rods, with a thin bushing. he would bore the bush to fit the crank, after it was trued. The rod was bored to just true, and then heated, the bush made to an identical OD, and cooled with dry ice. The 2 items were then assembled, and when temps equalized, an interferance fit locked the bush in place.
Your only other recourse, either braze in the bore and re-drill and ream to fit, or have another rod cast in bronze, using the original as a pattern. I think trying to braze these rods would be problematic, as the bronze would be oil soaked, and would present problems with adherence due to the oil impregnated in the material. |
I have a n.o.s rod if this would help someone. Db.
Hello. I know this is a long shot... but do you still have the maytag upright NOS connecting rod?
Jeff |
Bookmarks |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | F o r u m | Replies | Last Post |
Maytag 1946 72 twin connecting rods and caps needed | stitchwizzard | Maytag Engine Collectibles | 3 | 08-14-2016 06:07:28 AM |
Maytag 92,connecting rod alignment marks | techhi | Maytag Engine Collectibles | 6 | 03-04-2015 02:19:33 PM |
maytag 92 shimmed connecting rod need help | RandyBagley | Maytag Engine Collectibles | 6 | 12-10-2013 07:02:05 PM |
maytag 82 connecting rod | Clement Rook Jr. | Maytag Engine Collectibles | 6 | 05-24-2012 02:00:41 PM |
Maytag Upright - What do I have? | Kammer0072000 | Maytag Engine Collectibles | 3 | 11-28-2010 02:54:12 PM |
