Maytag Engines... built of Gold?
this thread has 29 replies and has been viewed 6004 times
Old 09-01-2016, 12:24:45 AM
rustyknutt rustyknutt is offline
Default Maytag Engines... built of Gold?
I ve been off here for a bit and into cars for a while. I came back on here and got some badly needed info.
I was on ebay a few months ago and noticed that apparently Mr Maytag was producing some Model 92 engines from precious metals and the price has risen into the hundreds of dollars. REALLY....???
Makes me think the collectors are gone and the hustlers took over. Opinions?? I have a dozen of them... paid upwards of 35 dollars for one of them. Most came out the the scrap yard for almost nothing.
I sort of thought this was a hobby where you took salvageable engines and made them run again for showing off. Looks like that may have went down the tubes.
Old 09-01-2016, 06:39:02 AM
G.M.Johnson G.M.Johnson is offline
Default Re: MAYTAG ENGINES...built of GOLD?
Nope, you are right, pretty much everything is driven off of greed anymore! But also remember the greed is driven by people who have deep pockets and keep paying high prices for items! Just my .02
Old 09-01-2016, 09:59:28 AM
Rusty knutt I would like to buy all of your running engines for $35 Ea. I think that your answer will be no. You can still go to auctions and buy Maytags for under $100 , rusty , not running. A seller can ask as much as he wants , but that doesn't mean he will sell it. I have a good running 92 that I will sell for $175. Am I asking too much? I had a question on anther thread about the 72 twins. How much is one worth? #1. Not running poor cond. ,#2 Good cond. not running. #3 good cond. running with original coil (could go bad at any time) , #4 Good cond. running with a new $150 coil. It will interesting to see your answers. Ron
Old 09-01-2016, 01:08:00 PM
Money is a big factor nowday. Im not selling the eight i have running as i like to take them to shows. Im not a vendor. Its a hobby and i enjoy it. One day i ll let them go. NOT for big bucks. but to someone who will enjoy them. Like all the other stuff i ve collected over the years. (40 years) i cant get to it ALL. so i m sharing my wealth of what i have....to get rid of it cause i ll never get to it....and to keep it out of the hands of the junk man who will give it to China just for weight. and yes.....i did sell an engine for 35.00 last week at Edgar Wi show. To an Amish teen who will fix it right and use it properly. Money sometimes is NOT the reason. PS. most of what i ve bought is parts stuff but still. once it goes to the junkman...its gone forever.
---------- Post added at 01:08:00 PM ---------- Previous post was at 01:05:17 PM ----------
Your .02 make a lot of cents. thanks.
I like this hobby of collecting agricultural engines/tractors/etc and keep it running so people can see the living history of how it used to be done.
The Following User Says Thank You to rustyknutt For This Post:
Old 09-01-2016, 02:26:30 PM
Exclamation Re: MAYTAG ENGINES...built of GOLD?
I used to pay 25-30 bucks for a 92 in near running shape. I would clean out the fuel tank and mixer, de-coke the exhaust and sell for $50, 75 if the paint was good. Now days, seems like you can't get one for less than 100, unless the owner just wants to get rid of it.
Condition, condition, condition! Price is mostly determined by condition, rarity, and how much someone is willing to pay! Here in NJ, 125 to 150 seems to be the going rate for a 92, in good shape. 175 for excellent condition, running. Things go down hill from there. Busted fins are a no-no, No spark cuts 50 bucks off the top! Bad rod also cuts into the price, by at least $25. If the engine is stuck, corroded flywheel etc, I wouldn't pay more than the 30 to 50 range. Lots of 92s out there, probably the cheapest Maytag out there.
The twins come next. The average here for the 72-D and DA are about 125 to 175 running and clean. Add $50 for the one with the WICO mag. Crapped up gas tank, bad rods, drops the price about 75 to 100 minimum, as cranks and rods are now at a premium. They can be found but you will pay for them. Bad main bearings - mag, pretty well devalues the engine to junk price. If you have to put a new magneto in the engine (175 off EBay), you probably will not get your money back. if you decide to sell the engine.
Buying an engine with no spark is a crap shoot. 50-50 wether you can get spark back, without major work and expense. Before replacing the mag, I would make very sure the rest of the engine is in good shape. Struck - rusty twin is worth about 25 to 50, depending on the mag, and is water got into the cylinders. if water was in it, junk price only.
Ronald, here are some estimates, given your descriptions: 1) depending on the rods and if not stuck - 45 to 70 dollars. If the flywheel turns and you do not feel the pistons move until the flywheel turns 1/4 inch, the rods are bad. At that point, it probably is junk. You might try and part it out - the block and cylinders may still be good. If seized, then the junk man probably would give you 2 or 3 dollars! 2) If the engine has just a dirty tank and pick up - gives you a jolt when testing for spark (even if it won't jump a plug gap), 75 to 100 would be a good bet for a buyer. 3) A good condition running 72-D or DA should be able to bring 125 to 175 at a show. All depends on paint and condition Just because the engine has the original coil, does not mean it is going to go bad. I have 4 or 5 72s with original mags, and they all run fine!. 4) Unfortunately, just because you have a new coil, the price remains the same as #3. A new coil does not add to the value - it just means that it will last longer than most originals. Believe it or not - a completely restored, with new paint, usually will not bring as much as an all original with good paint! The most I have seen a 72 with all original paint was 225, at a show. Engine was unused, still in the original box! You cannot go by EBay prices! An auction is a whole different animal, and the price is often run up beyond reasonable value. of course, you can put an engine on evilbay your self and see what happens. lots of strange folk out there! You could get the moon for it, or it could go for $50 bucks. it is an auction, and you take your chances.
if the engine has the WICO mag, add $50 to the prices mentioned.
The uprights and 82s are a different story. I have seen them as cheap as 150 and as expensive as into the thousands - again depending on condition. You also have to be careful of re-pros, especially the 'fruit jar versions.
Old 09-03-2016, 09:08:08 PM
Maytag Parts King Maytag Parts King is offline
Default Re: Maytag Engines... built of Gold?
rustygold for sure now days
You got to love Maytags,,,,,,
I'm giving one away Monday LABOR DAY,,,
check out my youtube channel for more info ligebellbuckletn
The Following 2 Users Say Thank You to Maytag Parts King For This Post:
Old 09-04-2016, 10:41:45 AM
eb68 eb68 is offline
Just an observation. Price is set by supply and demand. Since some of the posts or from those located in the north, could it be that the supply is greater the further north one searches? I live in Louisiana and there are no shows to attend that have supply to satisfy demand at any price; consequently, the Internet's high prices or the high cost of travel to purchase an engine or parts in the north may offset. I have paid, likely too much, for some parts, but I consider the decision as a cost to save an engine, to bring it back to running condition. I have to defend the high prices as lack of supply or maybe as travel costs saved lol. My 2 cents.
Here is a current challenge I have for your consideration. I need an Elkhart mag rebuilt for my motor wheel. I'm afraid to ship because these things are not replaceable. It cannot be rebuilt while I wait. I either have to ship it or bring it and then pick it up. There is no market in the south for such work. So, if one surfaces for sale, I have to factor those costs in determining what to spend. Recommendations?
Old 09-04-2016, 11:29:05 AM
Try selling a engine. Any engine. "oh my, the bearings could be bad,oh the flywheel is cracked, oh the compression is low" and so on. Before it is over the buyer wants you to throw in 20 bucks for gas to haul it for scrap. All this, Knowing the whole time more than likely he will sand the cylinder,rering it, mig the flywheel and grind it down to hide the crack,sand the bearings a bit and put some grease in there to help it spin and suck in fuel. Then set it out there for 150 bucks and reel in a customer, or should I say,a victim.
Now you try to buy a engine."Oh,that is just a casting mark, oh the rings are stuck,it just needs to be run it has been on the shelf a while, it is just tight from sitting you run it a while it will be fine. Oh that is a low serial number engine I am asking 150, but I tell ye what ,give me 140 "
Old 09-04-2016, 10:38:13 PM
Ohhhhh how many times i ve heard this....MANY. i look em in the eye and said....the going price according to the book todayis 25.00. I dont see a single person behind me bidding any more. and then i add ....you like it more that i. have fun reloading it.
Old 10-10-2016, 02:19:42 AM
stitchwizzard's Avatar
stitchwizzard stitchwizzard is offline
I found this model 72 on Craigslist. I believe it qualifies as one of the high end models spoken of here..
I have a question about the starting pedal. I have a model 72 with the same pedal and was wondering if they are rare for some reason?
This model does have older cylinders and the Bakelite air cap so IMHO it possibly may have 1937 model parts but I can't be 100% sure because no serial number is given.
$1000 firm asking price seems about $750 too high for my Maytag budget.
Stitch...
The Following User Says Thank You to stitchwizzard For This Post:
1904 Stationary, Marine, Gas and Locomotive Engines 437 + pages with gold leaf Paul Spence Antique Gas Engine Discussion 7 10-29-2012 07:30:24 AM
Maytag Engines and Gold Prices are Even rustyknutt eBay© Auction Discussion 6 04-15-2011 06:53:56 PM
Maytag Twin #321 Built MaytagRepairMan Maytag Engine Collectibles 2 10-17-2010 10:35:06 PM
Gold Standard upright 1/2 HP Maytag!!! Marc P Maytag Engine Collectibles 10 06-22-2009 12:43:07 PM
Maytag upright year built? Ihorse Antique Gas Engine Discussion 3 10-03-2007 01:36:03 AM
