Oil Field Engines
Project Thread: 20HP Reid Engine
this thread has 31 replies and has been viewed 6375 times
Old 12-27-2016, 11:14:50 PM
hitnmis Alex's Avatar
hitnmis Alex hitnmis Alex is offline
Default Re: Project Thread: 20HP Reid Engine
Here is my 20HP Reid. https://www.youtube.com/watch?v=nnmnE14mWSs
If it aint hittin its missin!!!!
The Following 2 Users Say Thank You to hitnmis Alex For This Post:
Old 12-29-2016, 09:42:12 AM
StrikeForce StrikeForce is offline
Originally Posted by hitnmis Alex View Post
That's exactly what we're shooting for here! If I get it looking or running anything like that, I'll be tickled pink. That's a nice runner you have there.
Old 03-05-2017, 06:02:40 PM
Its been a real slow winter here project wise. While I am traveling, I am making plans around the piston so once I'm home again I can hit it hard.
I have an inquiry into Niagara Piston to see what options I have for piston rings.
Second part is that I need to remove the wrist pin on the main piston to get the connecting rod out and separated. I want to check all of the bearings and such. Before I get too deep into this, can anyone confirm if the wrist pin is set to only go one direction? I remember by Myrick was and I am thinking this one may be as well? Appreciate any thoughts on this as the last thing I want to do is damage the piston at this point of the project.
Old 03-06-2017, 11:04:35 PM
Yes, I think you will find the wrist pin is directional. Bill Klein
Old 03-07-2017, 11:05:54 PM
Bill, I am thinking the side with the notch (right side if I am correct) would be the small side? This is also the side with the locking screw that has the countersunk notch for locking it in.
Old 03-10-2017, 09:34:13 PM
I don't recall which side was smaller but the pin will tap much easier one way than the other. The sound of the tap will be different also. just give it a try. Bill Klein
The Following User Says Thank You to W.P.Klein For This Post:
  #27
Old 08-28-2017, 04:45:15 PM
I am back at it! After what seemed like an eternity, I am back working on this project after having to travel for 6 months due to work.
The "tapping" out of the wrist pins didn't seem to be going well and I saw a potential to make things worse. So I stepped up and got a 12 ton press and pressed the wrist pins out. Wow! I am glad I did that. They were in there pretty solid.
Next phase is I have my pistons sitting in the electrolysis tank and I am working a lot of corrosion off the non-invasive way. I also built a custom cylinder hone so hopefully I can get that cleaned up and oiled. My #1 task staring me in the face is getting the water jacket bolts out so I can seal it up and do a water test. I want to make sure I don't have any cylinder wall leaks before I go too far down this road.
So my 2016 winter project has shifted to my 2017 winter project! It waited around long enough, another year wont hurt it. At least its been stored inside the garage all winter.
The Following User Says Thank You to StrikeForce For This Post:
  #28
Old 09-13-2017, 08:44:08 PM
Ran into my first hiccup on the project. I was laying out parts and pieces from my "parts box" and it looks like the flywheel wrist pin for the charge cylinder is from a different engine. My connecting rod bearings are 2.5" wide but the slot in the wrist pin is only 2" and it also seems to be too close to the flywheel. I am putting a "milk carton" ad out for a spare but I may need some help with dimensions if I need to make or have one made. That would be a bit of a bummer.
Old 04-02-2018, 03:58:59 PM
Well everyone, this has been a long, slow road (as expected) but we're making big steps now. I had to get a pin made to connect the fly wheel to the charge rod bearing as it looks as if I have a different flywheel compared to the rest of the engine. With that made, I got everything plumbed in. I will try and get some pictures off of my phone.
This weekend was the 4th time I have tried to start it. I took some advice on fuel settings and on the first attempt, I got a big BANG! and off it went for 3 hits. I think it ran out of fuel and then died out. After a few more attempts, I got it to fire off and I bumped the gas up (as I started recording). The Reid really took off on me so I quick hit the fuel shut off valve. Now its time to clean up the details, but its a runner once again!
https://youtu.be/3pZD9cbd5X4
The Following 5 Users Say Thank You to StrikeForce For This Post:
  #30
Old 04-03-2018, 02:34:16 PM
Exclamation Re: Project Thread: 20HP Reid Engine
it takes a bit of practice to get the fuel mixture right. Make sure you have a good low pressure reserve (accumulator) or you will have trouble getting the engine to run reliably. They do not like running directly off a regulator.
20hp Reid flywheels hitnmis Alex Oil Field Engines & Related Equipment 3 11-19-2013 12:02:20 PM
Opinion - Engine Rebuilding Thread - Big Project Wayne Grenning Antique Gas Engine Discussion 23 06-28-2011 08:27:42 PM
20HP Reid Kyle K Antique Gas Engine Discussion 7 11-02-2010 10:14:25 PM
Club Needs Some Help Reid 20HP Kevin Kusel Antique Gas Engine Discussion 0 03-19-2010 09:44:33 PM
20hp reid rod bearing TOM BABYLON Antique Engine Archives 1 10-08-2003 10:11:04 AM
