Oil Field Engines
Project Thread: 20HP Reid Engine
this thread has 31 replies and has been viewed 6360 times
Old 04-03-2018, 04:52:36 PM
StrikeForce StrikeForce is offline
Default Re: Project Thread: 20HP Reid Engine
Originally Posted by Andrew Mackey View Post
it takes a bit of practice to get the fuel mixture right. Make sure you have a good low pressure reserve (accumulator) or you will have trouble getting the engine to run reliably. They do not like running directly off a regulator.
Now that I know it fires, I want to play around with this a bit for sure. Along the way, I had read/been told that I could use a standard gas grill regulator. But I am stubborn and I was hoping to be accumulator free so I picked up a Fisher regulator that is rated for 1,400,000 BTU (R622-DFF). Based on volume, I had figured a minimum of 750,000 BTU and it was cheap enough so I figure I have plenty of volume. But, the downside to plenty of volume is that it wont starve that's for sure. After this weekend, I am more concerned about it running away before I get it dial in with the air.
I am sure it would also be easier if my fuel mixing valves would loosen up. As of now they are still stuck and this is 100% manual gas/air mixture control.
Old 05-20-2018, 06:15:08 AM
The Reid is starting to come back to life. Still need to get it dialed in better on the fuel side, but wanted to update this thread.
https://youtu.be/GrMgc6nH55M
20hp Reid flywheels hitnmis Alex Oil Field Engines & Related Equipment 3 11-19-2013 12:02:20 PM
Opinion - Engine Rebuilding Thread - Big Project Wayne Grenning Antique Gas Engine Discussion 23 06-28-2011 08:27:42 PM
20HP Reid Kyle K Antique Gas Engine Discussion 7 11-02-2010 10:14:25 PM
Club Needs Some Help Reid 20HP Kevin Kusel Antique Gas Engine Discussion 0 03-19-2010 09:44:33 PM
20hp reid rod bearing TOM BABYLON Antique Engine Archives 1 10-08-2003 10:11:04 AM
