Wisconsin Engines
Strange Points Related Problem With a VH4D
this thread has 15 replies and has been viewed 1693 times
Old 06-28-2018, 07:52:30 AM
rwk rwk is offline
Default Re: Strange Points Related Problem With a VH4D
I put a VW Bosch coil on a newly aquired VH4D on a hydro seeded and gapped the points to about .016, didnt have any info on it when I got it and we
were trying to get it running, fired right up, has run approx 10 hours so far, now I'am trying to get charging system working,25 amp stator style, believe reg and rectifier are bad, anyone have a fix or work around?
Old 06-28-2018, 08:15:07 AM
Like this?
If so, check for continuity between the two wires on the alternator. Nothing to ground. If that's good, go on ebay and find a hefty single phase motorcycle regulator/rectifier for under $20. Two wires from the stator to the rectifier and you then have ~14.5 volts output. Fuse the output at ~20 amps to protect it.
Old 06-28-2018, 06:03:07 PM
rwk rwk is offline
Ok, the stator is good, passed both test for continuity, my stator has 3 wires, do I not use the third wire? its red, the other 2 are black assume those are the AC out to reg/rect. Found some Kohler regs rated at 25 amps are those adequate?
Old 06-28-2018, 08:32:26 PM
You likely have a 3 phase system. *If all three wires are the same color.
So get a 3 phase bike reg/rec and you're good to go.
Something like this.
https://www.ebay.com/itm/Motorcycle-...kAAOSwhdZaVRUP
https://www.ebay.com/itm/US-Ship-Mot...UAAOSwU9xUMXLD
https://www.ebay.com/itm/Motorcycle-...QAAOSwcj1aN1TG
https://www.ebay.com/itm/12V-Motorcy...wAAOSwmNlZZe9D
Yellows to the stator
Red to battery
Green to ground
Old 06-29-2018, 07:06:37 AM
rwk rwk is offline
No, 2 black wires and 1 red, think only the blacks are the AC out of stator, what is the red one for? it was connected to the rectifier white wire, think it should have been connected to the red on regulator. PO had done some fixes, plug was burned to rect. and missing to reg. had some twisted wire and tape repairs. From the repair manual looks like 1 of stator wire goes to regulator assume red to red, then reg and rect are tied together? black to white then to amp meter, no colors listed on the schematic so I'm going by plugs which have color codes.
Like you say think a three wire reg/rect would work just what to do with 3rd stator wire?
Old 08-26-2018, 08:41:15 AM
RollinK RollinK is offline
Following, I'm having the same stator issue with a VH4D. Just acquired this engine, originally had the separate regulator/rectifier set up. Three wires coming off the stator, 2 black and 1 white. Getting a solid 30v AC off the 2 black stator wires. Connected them to the AC inputs on a Kohler 25a Rectifier, no output from the rectifier and the stator wires become hot very quickly. As several other have asked, does anyone know what the 3rd (white) stator wire does or should it be connected to anything?
Ohmed out the stator and it seems good, I'd really like to get this motor charging and could use some help on this one. Thanks Rollin
Onan 6.5nh Points Problem and Points Replacement and Adjustment mvimpvm Onan Generators 18 11-28-2017 12:11:05 PM
Ford LGT 120 Strange Problem HELP! Tom Schaech Garden Tractors / Mowers / Scooters 35 11-13-2013 03:46:06 PM
Wisconsin VH4D overheating problem mchunt Wisconsin Engines 6 06-16-2010 11:36:16 AM
Rebuilt VH4D backfire problem. tools Wisconsin Engines 11 06-14-2010 12:44:07 AM
Anyone else having this problem???~snow related~ Angela Antique Engine Archives 17 02-17-2003 11:08:34 PM
