Oil Field Engines
100 HP Patton Brothers Parts Wanted
this thread has 11 replies and has been viewed 2637 times
Old 01-01-2018, 10:02:02 PM
Earnie Hampton Earnie Hampton is offline
Question 100 HP Patton Brothers Parts Wanted
I am looking for a 5 to 7 inch ball type valve . We are trying to get started back to work on the 100 HP. Patton bros, again
The Following User Says Thank You to Earnie Hampton For This Post:
Old 01-02-2018, 12:34:42 AM
old sparky old sparky is offline
Default Re: 100 HP patton brothers parts wanted
got a lot of 5 and 6 in butterfly valves email me
Old 03-03-2018, 11:51:55 PM
D Davis D Davis is offline
Default Re: 100 HP Patton Brothers Parts Wanted
Hello : Do you have any information on these 100 HP Patton Engines ? I do know there was only 3 made but other than that I can not find any paper trail on these .
Old 03-04-2018, 09:06:17 AM
Skidmore's Avatar
Skidmore Skidmore is offline
A 100 hp Pattin was just removed about a mile from Cairo WV last month. The new owner said he has some of the original wooden patterns for the engine. I think it is # 3. The one Earnie has I'm sure came from McFarland WV thru Tom Schoolcraft. The pumpers always removed parts off it to keep Cairo station up and running. What are you missing ?
Skidmore aka engine hoarder
Old 03-16-2018, 09:11:41 PM
this is the Tom Schoolcraft engine. i am missing all of the intake and exhaust valve system.
Old 03-19-2018, 10:06:51 PM
Skidmore's Avatar
Being only 3 made that's going to be a challenge .
Old 03-22-2018, 10:15:28 PM
we are trying to home make enough stuff to make it run .
Old 01-05-2019, 10:26:18 PM
I am still looking for a large ball or rotating type of valve to make a exhaust port valve for the 100 hp Patton Bros. thanks Earnie
Old 01-06-2019, 11:10:44 PM
con-rad con-rad is offline
If you're not intimidated by making parts to get it to run, who not make a valve? I would think a plug valve would be fairly easy to machine. most ball valves have some kind of a plastic seat, which would make it unsuitable for exhaust.
Good luck with your project!
Old 01-06-2019, 11:59:09 PM
Nathan K. Nathan K. is offline
Good luck with your project that should make a nice rare engine. Has anyone gone to look for the original compressor(s?) for that engine-it was mentioned in another thread?, be great if they could stay with the engine even if not on it!.
Nathan.
Old 01-07-2019, 09:24:10 AM
Jeff Wahl's Avatar
Jeff Wahl Jeff Wahl is offline
I think there is a 90 HP at the Butterfield, MN show grounds. Not sure if it could help for reference? Maybe some parts were same size on the 90 and 100?
-Jeff
wahlengines.com
Old 02-07-2019, 02:36:28 PM
Question Re: 100 HP Patton Brothers Parts Wanted
If either one of the 2 others still exist, if you can locate them, perhaps the owner(s) would allow you to have copies made of the original parts (recast)?
Patton Brothers Engine Info David A. Oil Field Engines & Related Equipment 5 06-18-2016 07:04:43 PM
Patton Brothers 12hp jmadd Antique Gas Engine Discussion 0 07-09-2015 08:35:18 PM
Here is a 60 H.P. Patton Brothers Fred Van Hook Antique Gas Engine Discussion 4 08-16-2008 05:14:28 PM
12 hp Patton Brothers followed me home yesterday dannyinky Oil Field Engines & Related Equipment 1 05-07-2007 08:11:12 AM
need info and parts for 100hp patton bros. Earnie Hampton Oil Field Engines & Related Equipment 3 02-21-2007 08:53:21 PM
