Maytag Wash Tub With an old Frost Break, Help Please
this thread has 10 replies and has been viewed 1145 times
Old 02-28-2018, 04:46:00 PM
Tony Glaser Tony Glaser is offline
Default Maytag Wash Tub With an old Frost Break, Help Please
I decided to dig this out of the corner of the garage and get it running for the first time. Every thing went good until I added water to the tub when I des covered this break where it leaks. Any suggestions on a fix are welcomed. Thanks!
Old 02-28-2018, 04:48:28 PM
Default Re: May tag wash tub with an old frost break, help please
I don't know why I can't get more than one picture to load at a time, also why it's upside down. Bear with me as me and technology don't get along.
Old 02-28-2018, 05:14:38 PM
Power Power is offline
I would clean tub very good -down to bare metal, and clean with acetone or similar so epoxy has a good bonding surface. Spatula a thin layer of JB weld or equal on inside, and put a thick layer imbedded with fiberglass cloth on outside. If you use a marson spreader, you should be able to smooth repair so you do not need to sand later. Repair will show.
Old 02-28-2018, 06:59:43 PM
turbo's Avatar
turbo turbo is offline
Default Re: Maytag Wash Tub With an old Frost Break, Help Please
Tony your picture size is too big. When using your computer to upload photos first right click on the picture and hit edit, then resize, and it should say 100 in the box. type in 50 and save. This is what I have to do when uploading pictures from my I-phone. As for the crack possibly epoxy or jb weld from the inside of the tub then it would not be as noticeable. It appears the agitator must be seized onto the shaft to cause that crack otherwise the ice should have pushed the agitator up instead of cracking the bottom.
The Following User Says Thank You to turbo For This Post:
Old 03-01-2018, 09:39:31 AM
Old Iron Dave Old Iron Dave is offline
I have what I think is a machine of same model that has been converted to electric motor that I really don't need. Gear train is stuck, wringer looks OK, would like to find a new home for it. I'm 200 miles from you. P.M. me if you are interested. Thanks
Old 03-01-2018, 09:44:05 AM
AZBolens800 AZBolens800 is offline
I have one with a similar crack, I took it to a REALLY good tig welder and he was able to fix it.
The Following 2 Users Say Thank You to AZBolens800 For This Post:
Old 03-01-2018, 12:24:05 PM
Grape Grape is offline
Images: 12
These aren't that rare, I'd suggest looking for a parts machine on craigslist or local ads. It will probably be as cheap or cheaper than a good repair. Unless you just want it for yourself and don't care if a repair can be seen.
Either way, have fun with it.
Phil Grape
Remember, to Belittle others is to Be Little yourself
The Following User Says Thank You to Grape For This Post:
Old 03-01-2018, 12:50:53 PM
Grape, I agree I just like the original decals on this tub, I am looking into aquiring a different tub. But I might try fixing it from the inside, probably welding it. I have just never had much luck with jb weld. Thanks everybody for the input!
---------- Post added at 10:50:53 AM ---------- Previous post was at 10:45:01 AM ----------
Turbo, I almost always use our iPad to take and upload pictures. Most of the time I don't have a problem with the inverted pictures but sometimes I do maybe the agitator was struck at one time but I lifted it out fairly easily to inspect the crack from the inside.
I must have overpaid the guy I bought this from. (I think I gave you about $5 for this about 5 or 10 years ago) lol
Old 03-02-2018, 06:42:09 PM
Lawnboy Lawnboy is offline
I would grind out the crack to a V and either get it welded or epoxy it.
Old 04-29-2018, 11:17:00 PM
Candy T. Candy T. is offline
Hi Tony,
If you decided to fix it lease, post your results.
My son bought one that was the same way. I'd like to see your handiwork.
Thank You,
Candy
Old 04-30-2018, 01:01:22 AM
Motormowers's Avatar
I would take it all apart and vee the cracks out and use some Muggy Weld on it. Doesnt take much heat and flows well.
Remove the all rotten apples out of your basket of life and toss them in the trash where they belong.
The Following User Says Thank You to Motormowers For This Post:
Maytag Double Wash Tubs jboyer1028 Antique Washing Machines 1 10-17-2013 12:17:03 AM
Maytag Wooden Wash Machine with Upright engine Project Dennis Wyatt Antique Washing Machines 3 11-29-2011 03:59:52 AM
Is this a wash tub or what (still) ? richmud Antique Washing Machines 3 07-30-2011 06:57:08 PM
wash-out trowel Small Air Cooled Gasoline Engines 0 05-24-2011 07:22:12 AM
It's done and I can do my wash Tim Rostar Antique Gas Engine Discussion 12 08-20-2008 09:35:48 PM
