Oil Field Engines
Reid Start and Run
this thread has 7 replies and has been viewed 1275 times
Old 04-24-2018, 10:02:40 PM
OilfieldTrash OilfieldTrash is offline
Default Reid Start and Run
https://youtu.be/4RFiIydMXX8
Here's one more.
The Following 14 Users Say Thank You to OilfieldTrash For This Post:
Old 04-24-2018, 10:35:23 PM
Default Re: Reid start and run
GREAT to see one run in it's original setting! Bill Klein
Old 04-25-2018, 09:09:16 AM
Peter Holmander Peter Holmander is offline
Default Re: Reid Start and Run
Thanks for sharing !! Looks like it's running on well head gas. I don't see any propane tanks.
Old 04-25-2018, 10:47:00 AM
That's correct. The well that the engine pumps supplies the gas for the engine.
Old 04-25-2018, 12:31:08 PM
Vanman Vanman is offline
Is that a piston valve? Running at crankshaft speed, so this is a two stroke engine? Or? Very interesting!
Old 04-25-2018, 02:28:48 PM
Exclamation Re: Reid Start and Run
The Reid is a 2 stroke engine. It uses the Reid - LeClerk cycle. The intake is drawn into the charging cylinder, past an intake check valve, that is activated by a piston and con rod crankshaft throw that is 90 degrees away from the power piston throw. As the engine turns, fuel/air mix is drawn into the charging cylinder. It is then compressed. When the exhaust port on the power cylinder opens, this pressure is relieved by the gasses passing thru a passage, into the power cylinder, passing another check valves, as the exhaust gasses escape. As the engine continues to turn, the transferred gasses are now compressed in the power cylinder. As the piston nears TDC Compression on the power cylinder, the fuel/air mixture is ignited, either electrically (magneto), or by hot tube. The now ignited mixture expands and drives the power piston down the bore of the power cylinder. As it does so, the charging cylinder is drawing in a new charge. When the power piston nears the bottom of its stroke, the exhaust poet is uncovered and the cycle repeats.
The Following 4 Users Say Thank You to Andrew Mackey For This Post:
Old 04-29-2018, 07:02:32 PM
Arnold Walker Arnold Walker is offline
Looks a lot like the engines Lufkin Industries used on thier oil pumps.....had to rebuild them after they had been running in the fields for over 50years.
Old 04-30-2018, 09:58:52 PM
That one has been there since the mid to late 20s
The Following User Says Thank You to OilfieldTrash For This Post:
Onan 4k start/stop light doesnt work and stops running when release start switch JoshD Onan Generators 12 09-06-2014 07:51:40 AM
1913 IHC runs again throttle governing used John Deere H to start no bump start RobGill2008 Antique Gas Engine Discussion 1 08-17-2010 08:24:46 PM
Reid match and coffmen start. OldironPhil Oil Field Engines & Related Equipment 2 11-03-2008 09:45:26 PM
Why won't my 15 HP Reid start/run ? Bob Johnson Oil Field Engines & Related Equipment 9 10-05-2007 09:48:48 AM
Air start Reid Greg Downard Oil Field Engines & Related Equipment 9 07-02-2006 11:09:17 AM
