Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Unidentified Engines
Unidentified Engines Post your photos and questions about your unknown engine and look for answers here.
Possible International Harvester (?) early flywheel ID assistance
this thread has 4 replies and has been viewed 820 times
Old 05-01-2018, 02:50:41 PM
Texaco5 Texaco5 is offline
Question Possible International Harvester (?) early flywheel ID assistance
A neighbor of mine is thinking about buying this for his yard. It appears to be the sump and flywheels from an early gas stationary engine, and a large one at that. The closest I have been able to find is an International Harvester style engine, based on the style of the flywheel spokes which have bolt holes for accessory wheels etc.
This particular one is partially buried thanks to the passage of time, however I suspect that there is quite a bit more hardware under the dirt based on how deeply the flywheels are already buried.
Can anyone help identify the model and manufacturer of this half engine - note the bulge around the flywheel sump cover?
Thanks in advance
Name:	Stationary gas engine sump.jpg
Old 05-01-2018, 02:52:23 PM
David Babcock David Babcock is online now
Smile Re: Possible International Harvester (?) early flywheel ID assistance
Fairbanks morse y diesel. Db.
Old 05-01-2018, 03:19:53 PM
Default Re: Fairbanks Morse model Y
Many thanks David
The neighbor is thinking of using it for yard art however are the parts worth saving for someone with an engine they are trying to restore? Sadly it looks like the top end of the engine is long gone.
Also do you have any idea how much the bottom half and flywheels weigh as he is trying to figure out what he will need to use to dig it out/rescue it.
Thanks in advance
Old 05-01-2018, 04:58:27 PM
Joel Mosley's Avatar
Joel Mosley Joel Mosley is offline
Images: 27
Default Re: Possible International Harvester (?) early flywheel ID assistance
I looks like it has a clutch pulley that is worth saving as well. I could use one.
Old 05-01-2018, 09:08:35 PM
Dwayne Fuller's Avatar
Dwayne Fuller Dwayne Fuller is offline
Sell the clutch pulley to pay for the unit. It being gone will not detract from the yard art. The flwheels and crankcase are yard art. Looks to weigh about 2,000 pounds give or take. Much more info on the vintage diesel fourm.
International Harvester internal combustion engines early development& design (1918) TractorDom Antique Gas Engine Discussion 1 11-21-2015 07:33:51 AM
!048 International Harvester Cub David Scott Antique Farm Tractors 5 09-21-2012 06:42:16 AM
International Harvester LA LB DeereDr07 Antique Gas Engine Discussion 1 06-26-2012 11:30:09 PM
International Harvester The Lawnmower Man Horse Drawn Equipment 2 06-25-2012 12:12:34 AM
International Harvester 6HP help stevenkd5017 Antique Gas Engine Discussion 4 03-14-2012 07:22:59 AM
