Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Unidentified Engines
Unidentified Engines Post your photos and questions about your unknown engine and look for answers here.
1919 Cummins Model F
this thread has 6 replies and has been viewed 1137 times
Old 05-08-2018, 10:53:15 AM
RacerX335 RacerX335 is offline
Default 1919 Cummins Model F
I believe this engine to be built somewhere between 1919 / 1922 based on the fact that there is no serial number but built by Cummins. It's a single cyl and does run but I don't know how rare this engine might be, what they were used for or where it originated from. Anyone know who might have literature for something like this?
ID:	310012   Click image for larger version
ID:	310013   Click image for larger version
ID:	310014   Click image for larger version
The Following 9 Users Say Thank You to RacerX335 For This Post:
Old 05-08-2018, 11:25:16 AM
haywaj haywaj is offline
Default Re: 1919 cummins model f
Very cool. There is a video of a two cylinder on youtube. You should probably post this on the vintage diesel page. There is a fellow there who works for Cummins in their historical dept who will be able to help you. Jack
---------- Post added at 11:25:16 AM ---------- Previous post was at 11:24:06 AM ----------
Where did it come from, and what are you going to do with it?
The Following User Says Thank You to haywaj For This Post:
Old 05-08-2018, 11:43:57 AM
Thanks Jack,
It's a long story how I came to own it, eventually I'll sell it but need to know what I have first. My background is with heavy diesel and EMD power plant engines so it came to me as a project to make it run. After a lot of work on the cam box, valve train and sending the injector to PCE it came to life and actually runs really good. With Cummins 100 year anniversary coming up that might be a good idea. I've only found one like this one and it's in the Cummins museum. During my research I did come across the two cylinder model on youtube and eventually here.
Old 05-08-2018, 07:49:42 PM
CS Brown CS Brown is offline
Default Re: 1919 Cummins Model F
According to a Cummins Engine History article the first model F was produced in 1924.
The Following User Says Thank You to CS Brown For This Post:
Old 05-08-2018, 09:56:14 PM
K-Tron K-Tron is offline
Gene Shepherd of Long Island, NY, owns a one cylinder Cummins Model F which is in running condition.
Chris
The Following 6 Users Say Thank You to K-Tron For This Post:
Old 05-08-2018, 10:07:33 PM
Rich Mueller Sr's Avatar
Rich Mueller Sr Rich Mueller Sr is offline
I like his starter he uses on it!!, although it would be a little spooky if it got away from a guy!!
United Gasoline Engine Registry www.augermo.com
The Following User Says Thank You to Rich Mueller Sr For This Post:
Old 05-09-2018, 10:31:18 AM
Thanks to all who have replied, before running afoul of the rules here I'll move this over to the Diesel Forum to continue the discussion.
Avery 6 Cylinder Model C, 1919? 3v0 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 11 10-06-2017 07:16:41 PM
zenith carburetor model u 1919 marathon man Antique Autos and Trucks 0 06-03-2017 07:37:58 PM
Cummins Model U magneticanomaly Vintage Diesel and Oil Engines 2 05-22-2013 11:13:37 AM
4 Cyl. Wisconsin 1919? model TAU Help? JohnAW Multi-Cylinder Stationary Engines and Power Units 3 07-02-2011 07:00:27 PM
Need help 1919 moline univeral model d NDFalthead Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 09-19-2008 09:20:43 PM
