Wisconsin Engines
Help ID Possible Wisconsin
this thread has 5 replies and has been viewed 568 times
Old 06-13-2018, 12:44:11 PM
cwk266 cwk266 is offline
Default Help ID Possible Wisconsin
Hi could someone please lend their expertise to id this engine.I am only guessing its a Wisconsin with nothing more than it looks similar to a Wisconsin that I have on a sawmill.I have not been able to locate any identification tags on it other than a small piece of a patent number on the air shroud.Thanks for looking
Old 06-13-2018, 02:00:03 PM
DCamp DCamp is offline
Default Re: Help ID possible Wisconsin
It is a VE4 ( 3x31/4) or VF4 (3/14x31/4). It is an older unit as buy the oil filter and I do not see a starter.
Old 06-13-2018, 03:28:06 PM
Definitely a VE4. That one has been sitting for many years. They haven't made that style of oil filter can since the 70's.
Old 06-13-2018, 03:50:37 PM
K-Tron K-Tron is offline
It is either a VD4, VE4 or VF4. The only way to know which one it is, is to pull a cylinder head and measure the bore.
Chris
Old 06-13-2018, 05:18:25 PM
Thanks for the input if it is in fact a VE4 what would the horse power be?Any suggestions on reasonable parts stores BC Canada for this motor
Old 06-14-2018, 07:21:35 AM
edward moller edward moller is offline
Default Re: Help ID Possible Wisconsin
i belive you have a VF4, a VE4 would have had cast iron heads, two round clean out ports on the back of the air shrouding, & the old wire type of shrouding retaining clips over the cylinder heads
WISCONSIN Tractor Plowing at the 2017 Badger Steam and Gas Show, Baraboo, Wisconsin Craig A Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 01-30-2018 12:06:21 AM
Looking for Wisconsin TJD aort11 Wisconsin Engines 6 04-12-2016 03:13:53 PM
Wisconsin ABD propilot Wisconsin Engines 8 07-20-2011 06:26:21 PM
Hello from Wisconsin tvfd911 Smokstak Forums Meet and Greet 3 05-14-2010 02:28:16 PM
wisconsin ac4 michael mcginnis Antique Engine Archives 0 10-25-2004 12:57:48 PM
