Wisconsin Engines
Wisconsin THD - regulator YJ-59: How does it work?
this thread has 2 replies and has been viewed 703 times
Old 06-15-2018, 01:01:53 AM
PerJ PerJ is offline
Question Wisconsin THD - regulator YJ-59: How does it work?
I have a THD with a 12 V 10 amp alternator. There are four wires connected to the alternator. Two black wires are connected to the rectifier YJ-58, which is simply to diodes connected to engine ground. The white wire (center tap of windings) from the alternator is connected to the battery via the amp-meter. The red wire from the alternator is connected to the regulator YJ-59, and the white wire from the regulator is connected to the battery via the white wire (center tap from alternator) and the amp-meter. My question is about the working principle of the regulator. I have checked the manual, and the check procedure tells that the resistance should be infinity between all combinations of the wires to the regulator, and also between the wires and ground (in both directions). This tells me that there is something more than a simple diode inside the regulator YJ-59. Buying a new expensive regulator seems a waste of money if I can easily build a new one. Can anyone tell me how the regulator works, and what’s inside YJ-59?
Old 07-02-2018, 09:07:56 AM
rwk rwk is offline
Default Re: Wisconsin THD - regulator YJ-59: How does it work?
Yes, I to would like to convert my VH4D, both regulator and rectifier are bad in mine, however I only have 3 wires exiting my stator which is 25 amp, I'm trying to figure out how to use a standard 3 terminal combined regulator and rectifier, guessing certain wires must be combined on a 3 wire style, reg.dont want to use trial and error method! Cant seem to get any replies on how to.
Old 07-03-2018, 09:35:02 AM
s100 s100 is offline
I have two suggestions for you, you can remove your flywheel and examine the stator and magnets to see what is going on, or else you can put an oscilloscope on the output leads to see for sure what the thing is putting out. But from here it would be my GUESS that this thing is putting out three phase AC. If this proves to be the case you can, if you are really cheap, scrap the rectifiers out of an old Delcotron alternator or else buy a new set from a rebuilder. That will get you DC of whatever voltage the unit is putting out. Since you can't tinker with the field strength you get what you get, but one would have to guess that Wisconsin or whoever they bought that system from designed the generator to provide optimal output at rated speed since it is most likely the engine will be operating most often at that speed. Since you can't really change the machine's output you will have to add a current relay of some sort, either make or buy one.
The causal observer may question, "Why would anyone go to such a fuss? Why not simply buy the parts from Wisconsin?" This is of course a good question, but assuming the parts are even available (a big IF) the prices would be absurd and the electronics associated with these systems were not exactly known for their robustness. So coming up with an alternative is a good idea.
Wisconsin Stationary Engine, How do I work out how many horsepower? Britstand Smokstak Down Under 12 04-01-2018 03:57:24 AM
will a mx321 voltage regulator work in a 30 ek onan machine? 1baker016 Onan Generators 7 02-01-2016 10:43:09 PM
G204 rectifier/regulator change Wisconsin to Kohler spocter72 Military MEP and Aircraft Gen-Sets 2 03-28-2014 11:18:24 AM
Will this work on my Wisconsin AEH? Chris Schmidt Magnetos, Ignition Coils and Spark Plugs 0 01-16-2011 04:11:38 PM
Wisconsin TH with Ensign propane regulator Shootist357 Generators & Electric Motors General Discussion 18 01-27-2006 09:45:14 AM
