Wichmann Hot Bulb Diesel Donation
this thread has 2 replies and has been viewed 761 times
Old 08-08-2018, 09:45:59 PM
con-rad con-rad is offline
Default Wichmann Hot Bulb Diesel Donation
Recently at the Zagray Farm Museum, we received a donation from the Mystic Seaport of a Norwegian-made Wichmann semidiesel. After removal from it's original vessel, it spent some time in Coolspring, and from there it went to Mystic Seaport where members spent many hours restoring it. after they had it on display for a number of years, they decided to donate the engine to our museum. Our first task was to replace the cracked timbers it was on with some fresh oak cut on our sawmill. Not a hard job at all for our Northwest 80D crane!
https://www.youtube.com/watch?v=LzaTxpW2ErM
This engine was a running donation, so after some plumbing is done for fuel and starting air, we'll have it ready as a running display!
connor
The Following 4 Users Say Thank You to con-rad For This Post:
Old 08-09-2018, 06:48:48 AM
Peter Holmander Peter Holmander is offline
Default Re: Wichmann Hot Bulb Diesel Donation
Nice engine. Will have to get to Zagray now to see it run.
Old 09-23-2018, 10:07:41 PM
Got the Wichmann running today, it just barely turns over at 120PSI air pressure (we're in the process of upgrading our high pressure air). It runs ok, but it almost immediately pulled lag bolts out of our skid and pulled concrete anchors out of the floor that were holding it down! We will need to do some re-thinking and improving on our skid before we can really run it at all.
Also, if anyone has any info on the governing/throttle linkage on these engines, let us know. currently the throttle is controlled directly by hand, opening or closing the injection pump rack.
connor
Diesel and hot bulb KevinGWeq Antique Gas Engine Discussion 3 01-10-2014 07:41:01 PM
Detroit Diesel Hot Bulb nicholaskheinrich Vintage Diesel and Oil Engines 6 09-07-2012 09:53:30 PM
Hot Bulb Semi-diesel PERCUSSION!!! Daniel Dorece Antique Gas Engine Discussion 8 12-12-2009 03:42:28 PM
1934 Wichmann Diesel questions Chrissy Antique Marine Engines and Outboard Motors 3 04-21-2008 02:48:57 PM
15HP FM Hot Bulb Diesel JWForney Antique Engine Archives 2 01-03-2001 09:08:44 PM
