Unidentified Engines Post your photos and questions about your unknown engine and look for answers here. |
Compressed Air Mine Hoist?this thread has 11 replies and has been viewed 1203 times
I came across these pieces of equipment in the desert of central Arizona. I am trying to understand how the mine hoist operated. Wonder if it was an air hoist that could have been powered by the air compressor? Any thoughts appreciated.
The Following User Says Thank You to Toysx2 For This Post:
Sponsored Links |
If you tell me where these are,I will go look at them and get back to you
One looks like a Fairbanks Morse N engine with a cable winch on the back of it, and the other one looks like a belt driven air compressor.
The Following User Says Thank You to RustySteele For This Post:
Thank you for the response. Your info gives me a place to start on the hoist engine. 1906 newspaper accounts of the mine note that a 25 hp gas engine and an air compressor were at the site.
The item with the winch, is definitely a gas engine - the pot muffler is still attached! Have a close look around - the missing parts may be on the ground nearby. Sometimes a metal detector comes in handy! do you know what was mined there?
Things haven't changed much since I stumbled upon this picture in June of 2015. Hot tube chimney is moved a bit.
Investors were mined. 1.7 million shares of worthless stock were sold in this mine from 1906 to 1908. In 2017 dollars that amounted to 4.7 million dollars. 4 of the promoters were sentenced to a year in Leavenworth. Two took off for Canada. One was pardoned. It is unknown what happened to the fourth......The mine was promoted as a gold time with ore averaging $200,000 per ton.....
---------- Post added at 05:30:21 PM ---------- Previous post was at 05:27:41 PM ---------- Ed. This photo is one that I took. When I learned more of the mine's history, I returned for a second look. |
problee to run jack hammers
Poking around elsewhere on Smokestak, I believe that the hoist pictured on the semi trailer is almost exactly the one in my photo.
https://www.smokstak.com/forum/showthread.php?t=130139 |
From a 1908 catalog here is some information that might be of interest. Looks like that by counting some teeth on the gears you could determine the HP of the engine.
Larry Evans |
The Following 2 Users Say Thank You to Larry Evans For This Post:
Bookmarks |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | F o r u m | Replies | Last Post |
Hoist Engines in a Mine | Chris Props | Steam Stationary Engines, Traction Engines, Steam Boats | 2 | 11-13-2017 12:50:20 PM |
ID mine hoist engine | Toysx2 | Unidentified Engines | 6 | 07-22-2017 10:19:58 PM |
Gantry hoist or A Frame Hoist | treasurechest | Machine Shop and Tool Talk | 7 | 12-20-2011 02:13:52 PM |
Compressed air fittings | Tonto10 | Vintage Toy Steam Engines and Motors | 3 | 08-07-2008 07:30:30 AM |
wet compressed air | Joseph Musser | Antique Engine Archives | 14 | 07-12-2004 03:04:55 AM |
