Cushman Binder Head Question
this thread has 13 replies and has been viewed 1422 times
Old 08-19-2018, 05:29:40 PM
Smoke Smoke is offline
Default Cushman Binder Head Question
Hi folks, pick up a rough Cushman Binder to play with and noticed that on the head area, their are two flats milled out of it (Circled in red) I looked at others on the web ans some have this area milled and some are domed without it. I think is an earlier model as it is Battery and coil only setup with no mag brackets. The serial number starts at 25. Any ideas ? Thanks Smoke
Name:	Cushman Binder Head.jpg
ID:	316639   Click image for larger version
Old 08-20-2018, 09:19:42 AM
Andy Williams Andy Williams is offline
Default Re: Cushman Binder Head Question
i have one that is like that. mine is a later one made in the late 30s-early 40s i thought it might have been for another gas tank mount or something. mine has a wico X mag.
Old 08-20-2018, 09:34:38 AM
Hi Andy, whats your serial number if you don't mind. Mine is 25557.
Old 08-21-2018, 07:33:01 AM
mine is a model C34 listed at 4-6 hp serial # is A48546 i was told it was made from around 1936-42
Old 09-13-2018, 11:28:01 AM
myfasttsi myfasttsi is offline
i have a cushman binder engine with a seirail number of 4869.
Old 01-10-2019, 10:36:34 AM
i just bought another one last week the serial# is just a few numbers off from yours but it has a slick head no flat places. it also has a battery and coil and is on an original cart, except replacement wheels, with original gas and cooling tanks. it was bought new in Colorado. i don't know the age of it probably before 1920 ?
Old 01-10-2019, 02:50:46 PM
Heller D. Davis Heller D. Davis is offline
The short intake valve makes it an early one.
Old 01-12-2019, 06:42:24 PM
Kfigge73 Kfigge73 is offline
Can anyone tell me what year this was made? Thank you.
Old 01-14-2019, 08:38:13 AM
I checked and mine is #25517 but has tall intake but probably a replacement
Old 01-14-2019, 11:06:52 AM
Ret AF Ret AF is offline
I have two engines, serial numbers 43580 and 24409. I understand that there no records left from the factory that built these engines, and tracking them down on year made is impossible? Someone correct me on that. It seems like there were many, many variations of this engine, or were they just improvements over the years?
Old 01-15-2019, 09:19:42 AM
Dan Baalman Dan Baalman is offline
I had eleven of those C's at one time, and nearly every one was different in some way. A couple had those flats on the top. I thought they were bosses that could be drilled and tapped for something. I sold every one of them to Mr. Cushman, Jim Brown in Nebraska. He was a great man.
The Following User Says Thank You to Dan Baalman For This Post:
Old 01-15-2019, 11:59:52 AM
The cubs are like that too. i have a few and all are slightly different mostly small parts being made of different materials, steel, aluminum, brass, pot metal.
i guess the only way of getting age is to have some original bill of sales with serial # on it or if some original owners told family when they bought it.
I asked the guy i got my last one from and he said it was on a place his father bought years ago about 11,000 ft elevation in Colorado. the engine was old and rusty then but not stuck so he got it going.
Old 01-21-2019, 10:05:11 AM
Mark N Mark N is offline
Hello,
I have a 4 hp Cushman serial number 27,654.
I have posted this before, but will repeat it here. A number of years ago an old invoice was sold on Ebay. Its was dated June 11, 1919 and it was for two 4 hp skid outfits with serial numbers 31,598 and 31,550.
All the best,
Mark
The Following 2 Users Say Thank You to Mark N For This Post:
Old 01-23-2019, 09:31:54 AM
Mark
that's the way to get an estimate, if a few more turn up like that we could get an idea of dates produced. maybe one just every 2 to 3 years apart would do it. so now we know ours and some others were made before 1919. andy
The Following User Says Thank You to Andy Williams For This Post:
Cushman binder carb question Zira Antique Gas Engine Discussion 3 06-27-2014 06:32:20 PM
Old Cushman Binder Engine, New Cushman Owner Short Circuit Antique Gas Engine Discussion 3 05-19-2010 09:06:38 PM
Cushman Binder engine timing question Bob Johnson Antique Gas Engine Discussion 2 10-24-2007 06:48:35 PM
cushman binder scott wendling Antique Engine Archives 3 03-18-2002 12:39:56 PM
2 hp Cushman Binder John Ledbetter Antique Engine Archives 0 03-08-2002 07:51:44 PM
