2-71 Detroit Diesel Spewing Oil From Exhaust
this thread has 21 replies and has been viewed 1584 times
Old 09-25-2018, 08:49:44 PM
Phil P Phil P is offline
Default Re: 2-71 Detroit Diesel Spewing Oil From Exhaust
Hi
We had a 4-71 that hadnít run for years. When I first started getting it ready to run I found it had a stuck injector.
When I removed the rocker cover to fix this I found the unit had apparently been overhauled installed and test run but never started again.
After the startup it ran well but dribbled oil out of the exhaust pipe so bad we had to put a bucket under the exhaust to catch the oil.
It was on an 8,000 gallon a minuet irrigation pump so we hooked an 80 gallon fuel tank to it and cranked it up to 2,000 RPM running the pump. We only shut it down twice a day to check oil.
Other than that it ran 24 7 for 2 weeks it no longer uses oil.
Phil P
Old 09-26-2018, 10:04:37 AM
miltruck miltruck is offline
Another thing I just thought of is what is the temperature of the coolant in the engine when you are running it? Detroit's don't like to be cold, they run best at 170+ to 190 degrees @ the water outlet (thermostat housing). Running without a load, the engine most likely will never hit the thermostat rating. All that air blowing through the engine makes it act air cooled. Use one of the handheld touch less temperature units (cheap at Harbor Freight) to see what the various areas around the engine are at.
You could try removing the fan only and just run the water pump or block off the air flow through the radiator as an experiment.
And as stated a couple of times before, a good load on the engine would help immensely. Anyway you can do that? We bought a 30kw 100,000 btu 3 phase portable heater off Craig's List for cheap money ($100) to load and test our 2-71 30kw unit. Runs as if nothing is even hooked up but does also jump the coolant temps right up there fast. Fuel use also goes up; about 2 to 2.5 gallons per hour under load.
Detroit diesel / GM diesel engine MatthewT Vintage Diesel and Oil Engines 11 07-17-2017 05:46:51 AM
371 detroit diesel lawnsbylane Multi-Cylinder Stationary Engines and Power Units 4 04-01-2013 09:13:38 PM
Detroit Diesel Elec Power DDC25U with Diesel Perkins Engine Manuals? MP5ForTheWin Generators & Electric Motors General Discussion 4 08-14-2012 12:34:30 AM
Help With a Detroit Diesel 6-71 wild800 Generators & Electric Motors General Discussion 20 01-13-2012 10:22:11 PM
Tecumseh HS-50 Spewing oil! Help? bluedeacon Small Air Cooled Gasoline Engines 18 12-10-2011 06:37:16 PM
